What happens when I put cube and square doubles in a matrix?
  • Context: Graduate
  • Thread starter Thread starter noogies
    Cube Square
This discussion focuses on the construction of symmetric functions involving cube and square doubles, specifically using the algebraic number x and its powers. The author presents a series of values and explores the implications of placing these functions into a matrix, emphasizing the concepts of composition and decomposition. The analysis reveals the relationship between the functions f and q, which represent different twisting positions of a Rubik's cube, and highlights the significance of their interactions in the context of symmetry groups.
  • Understanding of algebraic numbers and their properties
  • Familiarity with matrix functions and operations
  • Knowledge of symmetry groups, particularly in relation to Rubik's cube
  • Basic concepts of graph theory and function composition
  • Research matrix function applications in algebraic geometry
  • Study the properties of symmetry groups in combinatorial puzzles
  • Explore the implications of function composition in graph theory
  • Investigate the works of Fowler, Gardner, and Baez on Rubik's cube algorithms
Mathematicians, computer scientists, and puzzle enthusiasts interested in algebraic structures, matrix theory, and the mathematical foundations of combinatorial games like the Rubik's cube.
noogies
I think I've managed to construct a symmetric set of functions, that let's a [tex]x, x^2, x^3\;[/tex] double an algebraic number.
I have a series that goes {6,9},{27,54} already. If I set x = 3, then I replace these terms with [tex]\; \{ 2x, x^2 \} ; \{ x^3, 2x^3 \}[/tex]
I have the series and a symmetric set of functions; can I put these in a matrix, and what happens if I do, I'm going to need matrix functions?
This is just something that fell out of a posted list of the first two sets of combinations for the pocket Rubik's cube - is it the "doubler" I need though? I mean, there it is...
ed: whoops, bracketed as it should be.
Ok, I had a thunk about this, and the problem per se, is about composition and decomposition.
If I start with a cube, I can see 3 faces of it; This is the first d/dx = 3 square products from a cube (product). Next d/dx on 3 squares (now disjoint) gets 6x, then x. That is, 3 squares decompose into 6 edges or nodes, then into a single "X" crossing remains in G.
Take 1 x and square it; double the square, and so on to re-integrate. The 2-sliced cube is obviously algebraic, there are [tex](8-1)!3^7[/tex] digits in the number, each is a squares product in a subgroup of squares.
But the next duple is {120,321} or {321,120} since the order of the "results" is irrelevant (each is independent functionally), and so is the operator order, except for the asymmetry: [tex]3x^2 \;> 2x^3[/tex], which implies a subtraction.
This makes sense because the outer function "looks ahead"; you can see in the chart for G that the two generators are out-of-phase at n > 0. The f o g must borrow states from q; q is the inner "algorithmic series" which is the most descent; f is least. Assume the first 15+m states for f and q are distinct, up to some value for n where borrowing means the f-list has connections to q's algebra and copies states. The f and q lists are also copies so they double |G|.
The physical cube isn't doubled its orientations are (for each crossing in X).
This is the list in question, which I believe is a density chart of the rationals in |G| = N-1.
There are 15 intervals (n) which is the same # as the values for f and q added together. The doubling of Q the quotient is seen in the two functions (full and quarter turns are "double" and "split" moves), that are out-of-phase from n = 1. These are two "path operators" because you can switch from f to q during a graph-walk. The connections between the individual quotients, and how this is ordered by n is what I'm interested in. The f gets ahead of the q function so it must borrow states from Q, or the inner quotient is generated in smaller intervals; at what point is the first congruence in f and q?
This is pursuant to reading up some papers, including Fowler's, some of Gardner's and Baez' online editorial about the symmetry groups and Rubik's especially. I realize this is only one aspect of a much larger domain.
Code:
The number f of positions that require n full twists and number q of positions that require n quarter turn twists are:
n 	f            q
0 	1            1
1 	9            6
2 	54           27
3 	321 	     120
4 	1847 	     534
5 	9992 	     2256
6 	50136 	     8969
7 	227536 	     33058
8 	870072       114149
9 	1887748      360508
10 	623800       930588
11 	2644         1350852
12                  782536
13                  90280
14                  276
  • · Replies 59 ·
  • · Replies 17 ·
