Uncertainty of binomial distribution?
The discussion centers around finding the uncertainty associated with a signal derived from two binomial distributions, specifically the difference between the counts of two outcomes (yes and no). Participants explore various aspects of uncertainty measurement, including standard deviation, covariance, and the implications of independence between distributions.
  • One participant seeks help in determining the uncertainty for counts N(yes) and N(no) in the context of a signal defined as Signal = N(yes) - N(no).
  • Another participant suggests using the standard deviation as a measure of uncertainty and mentions the propagation of error, noting that the error of a difference is larger than the error of individual components.
  • A participant expresses confusion regarding the term COV_{ab} related to covariance and requests clarification on its meaning and application.
  • One participant proposes checking the independence of the two binomial distributions, stating that if they are independent, the covariance would be zero.
  • Another participant describes the uncertainty calculations for two types of events (same-sign and opposite-sign) and seeks to understand the uncertainty of the function N(os) - N(ss).
  • One participant asserts that the problem involves only one binomial distribution, reformulating the signal as a linear transformation of a single binomial variable and discussing the Shannon entropy related to it.
  • A later reply indicates that the original poster has gained insight from the discussion and expresses gratitude, while also raising a new question about the uncertainty of the total count N(total) as it is a sum of binomial distributions.
Participants exhibit varying levels of understanding regarding the concepts of covariance and independence in the context of binomial distributions. There is no consensus on the best approach to calculate the uncertainty, and multiple views on the nature of the distributions and their relationships remain present.
Some participants express uncertainty about the definitions and implications of covariance, as well as the independence of the distributions involved. The discussion reflects a range of assumptions and interpretations regarding the statistical treatment of the problem.
penguindecay
Hi, I'd like to know how to find the uncertainty of a function that has two binomial distribution s, something like
Set p = 0.6 for yes. My problem is that I do not know how to find the uncertainty for N(yes) and N(no), and do not know how to find the uncertainty for the signal. Any help would be great! Thanks
One measure of uncertainty is the standard deviation, which is the square root of the variance. See http://en.wikipedia.org/wiki/Binomial_distribution" , since the error of a difference is larger than the error of either of the components. Does this help?
Everything made sense except the propagation of the error. I did not understand the equation given, it had a term COV_{ab} which I have never seen before, and reading the page on covariance does not help as I understand very little of it. Could you give me an equation or explain the term COV please?
That is a complication, but first, let's check if your two binomial distributions are independent. If they are, then the covariance is zero. (The covariance is a measure of whether the two distributions are correlated.)
The first is of events that are same-sign (ie ++ or --), while the other is the number of events that are opposite sign (+-), called N(ss) and N(os) respectively. I've taken the uncertainty of these two as:
SQRT( N(os).p_os(1 - p_os) ) and SQRT( N(ss).p_ss(1 - p_ss) )
I would like to know now the uncertainty now of a function that is N(os) - N(ss)
OK, that doesn't look independent. I haven't run into this type of problem before, so unfortunately you'll need somebody else to stop by and help.
Ok, Thank you for helping though!
Okay, well you really only have one binomial distribution here. N(yes) - N(no) = N(yes) - (N(total) - N(yes)) = 2N(yes) - N(total)
This is a linear transformation of a single binomial distribution where n = N(total). Specifically if X is distributed as B(n,p) then your variable is 2X - n.
When you say "uncertainty" you also refer to the "uncertainty of the signal" which makes me think you are talking about the Shannon entropy of the variable. The Shannon entropy of 2X-n is the same as the Shannon entropy of X (assuming that n is a constant and not a random variable), and the entropy of X can be looked up since it is binomial. According to http://en.wikipedia.org/wiki/Binomial_distribution, the Shannon entropy of X is [tex]\frac{1}{2} \ln \left( 2 \pi n e p (1-p) \right) + O \left( \frac{1}{n} \right)[/tex]
Thank you, I had not thought of considering it as a function of only the n(yes) or n(no), that helps a lot. The uncertainty is to do with a measurement of the signal, ie 112 events +/- 10.6 events, originally this was posted in the physics section. But I think I can solve it with the treatment you have told me about, I am grateful to you,
Kim
Kim
Actually I got the same problem on what the uncertainty of the n_total is as it too is a sum of binomial distributions
