What Is the Difference Between Potential and Potential Energy?
The discussion revolves around the concepts of potential and potential energy, specifically their definitions and differences. Participants are exploring why it might be more useful to consider potential in certain contexts rather than potential energy, particularly in relation to conservative force fields.
  • Conceptual clarification, Assumption checking, Mixed
  • Participants are attempting to articulate the differences between potential and potential energy, with some expressing difficulty in verbalizing their understanding. Questions about the mathematical definitions and implications of these concepts are raised, including the role of conservative fields and the significance of the negative sign in potential calculations.
There is an active exploration of the relationships between potential, potential energy, and related concepts such as voltage and electric fields. Some participants have offered analogies to clarify these distinctions, while others are questioning the conventions used in physics regarding these terms. Multiple interpretations and lines of reasoning are being examined without a clear consensus.
Participants are navigating the challenge of explaining abstract concepts in a way that avoids simply restating textbook definitions. There is a recognition of the need for clarity in distinguishing between properties of fields and properties of charges within those fields.
Sigma Rho
An apparently easy question that has got me baffled! The question is simply "What is the difference between the potential of a body and the potential energy of a body, and why is it sometimes more useful to consider the potential rather than the potential energy?".
I know the answers (I think! :smile: ), but I'm having great difficulty in putting them into words. I guess there would be no marks for just copying stuff out of the textbook, so how do I go about explaining it?
I'm not very good at "wordy" questions (I much prefer to work with equations), so if anyone has any advice about this kind of question in general, I'd be glad of it.
Thank you.
From my understanding, potential energy is the energy associated with the ability to do work.
I've never heard of a body having potential before. Mathematically speaking, whenever a force field (vector field) is conservative, there exists a scalar potential function [itex]f[/itex] such that [itex]\vec{F} = \nabla f[/itex]. I don't know if this has anything to do with the potential of a body though.
I will say "voltage" instead of "potential" for clarity (voltage = potential).
Potential energy comes from the interaction between two objects (i.e. two charges).
Voltage is bascially the potential energy stripped of one of the objects, so it's even more abstract.
Let's take charge as an example. It interacts electrically. You can sort of think of the voltage at a point in space as what the potential energy would be if there were a unit charge at that point. This makes some calculations more convenient, because then you can just scale the voltage by the amount of charge that is there to get the potential energy. One key difference between voltage and potential energy is that, while voltage exists (is defined) at every point in space, potential energy doesn't exist at any point in space. Furthermore (to amplify the distinction), voltage only requires one source charge (that is not necessarily interacting with any other charge), whereas potential energy requires two charges (that interact with each other).
The distinction is analogous to the distinction between force and force field. For instance, the Coulomb force is the force that one charge exerts on another. The electric field is the force that a charge would exert on a unit charge if there were a unit charge to exert the force on, but there does not have to be another charge out there for there to be an electric field out there. There does have to be a charge out there for there to be a Coulomb force out there. Thus, in this analogy, the coulomb force is analogous to the potential energy, and the electric field is analogous to the voltage.
You can observe these relationships:
F = qE
U = qV
F = -gradU
E = -gradV
or there reciprocals:
E = F/q
V = U/q
U <- integration of F.dx
V <- integration of E.dx
It seems that in physics there is a negative sign involved when determining the potential, i.e. [itex]\vec{F} = - \nabla f[/itex]. Why is this?
I was just thinking this. Very nice analogy turin. I think this should clear things up.
It is more of a matter of convention than anything else, AFAIK. In my unofficial opinion, though, I think it speaks something of the 2nd law of thermodynamics.
"Potential" is a property of a conservative electric field.
"Potential energy" is a property of a point charge in that electric field.
Consider a one-dimensional potential-energy diagram.
Consider a small displacement near a stable equilibrium point.
The restoring force is minus the slope of the potential energy curve.
When displaced to the left, the slope is negative. So, the restoring force is positive ("to the right").
When displaced to the right, the slope is positive. So, the restoring force is negative ("to the left").
. Why is this?
The negative sign arises from the very definition of potential energy; the one you learned in mechanics. Remember that the potential energy of a system is the work done at no change in kinetic energy in a conservative field (in this case the electric field). This quantity is of course divided through by the second charge in the system, but nonetheless: Imagine a fixed positive charge in space. Now imagine a positive "test" charge being brought closer. This charge isn't accelerating either, it's coming in at no change in kinetic energy (finding the potential.) Now thinking of a free body diagram, you should see an electric force vector pointing out of the test charge parallel and in the same direction as the electric field of the source charge. In order to keep the charge from accelerating (and thus changing its kinetic energy), one must "push" forward on the test charge with a force the same magnitude as the electric force vector caused by the source. Only problem is that this vector is pushing in the wrong direction, so you simply multiply it by a negative one; now you have a vector of the correct magnitude and direction as to cause no acceleration of the test charge. Now simply integrate over the distance and you have the potential.
  • · Replies 23 ·
  • · Replies 22 ·
