Misunderstanding of isomorphism and automorphism
  • Context: Graduate
  • Thread starter Thread starter Sumanta
    Isomorphism
This discussion centers on the theorem from Robert Ash's lecture notes regarding finite separable extensions in abstract algebra. Specifically, it states that for a finite separable extension E/F of degree n, an embedding sigma of F in C extends to exactly n embeddings of E in C. The participants explore the geometric interpretation of automorphisms and isomorphisms, particularly in the context of R^3 and its relationship with R. The confusion arises around identifying automorphisms among various transformations of vectors in R^3, leading to a deeper inquiry into the nature of these algebraic structures.
  • Understanding of finite separable extensions in field theory
  • Familiarity with the concepts of isomorphism and automorphism
  • Basic knowledge of algebraic closures, specifically C as the closure of R
  • Experience with polynomial equations and their roots, such as x^3 + 2 = 0
  • Study the properties of finite separable extensions in field theory
  • Learn about the geometric interpretations of algebraic structures in topology
  • Explore the concept of automorphisms in vector spaces and their implications
  • Investigate the relationship between polynomial roots and field extensions
Students and researchers in abstract algebra, particularly those interested in field theory, automorphisms, and the geometric interpretations of algebraic concepts.
Sumanta
Hello,
I was doing self studying abstract algebra from the online lecture notes posted by Robert Ash and I hit against the following theorem. I am posting it in the topology section because without a geometric/topological meaning to the concept I am never able to understand the topic and that is the reason during my undergraduate days 8 years ago I did not pass in algebra at all.Now for the theorem: Let E/F be a finite separable extension of degree n and let sigma be an embedding of F in C (where C is the algebraic closure of E). Then sigma extends to exactly n embeddings of E in C. In other words there are exactly n embeddings of tau in C such that restriction of tau to F coincides with sigma. In particular if sigma is the identity function on F then there are exactly n F-monomorphism of E into C.The above is reproduced in ditto from Thereom 3.5.2 of R.Ash lecture notes posted on his website.
Now my question.
Let me think of E as R^3 and F as R. Now surely R^3 is the closure of R. (The reason why I have taken R^3 is simply because I am successful in proving the theorem in 2D, using x^2 +1 = 0 and things like that. Now when I tried using x^3 +2 = 0, I understood that I would be getting 6 dimensions of the separable field. )
My hunch would be automorphism could be thought of as vector rotations and hence I thought of coming out with this simple example. Surely having T(a) = a + 1 is an isomorphism but not an automorphism which fixes a.
So I thought of taking the following isomorphisms of a vector .
(x, y, z) ---> (x, y, z) (identity)
(x, y, z) ---> (y, x, z)
(x, y, z) ---> (z, y, x)
(x, y, z) ---> (x, z, y)
(x, y, z) ---> (z, x, y)
(x, y, z) ---> (y, z, x)The above are some kind of transformations I thought which are possible.
If the theorem above is true then at least 3 of the above isomorphisms should not be an automorphism. I am really not sure which 3 of them should not be and why not. I have tried a lot to think but have been unsuccessful.The theorem says that the transformation when restricted to F then it should fix F. Now I could think that since the extension of R^3 is over R hence x should be fixed but I only get 2 automorphisms. The identity and (x, y, z) ---> (x, z, y). Not sure why I am not getting the third one, because the theorem says that E/F is of degree n ( which is 3) and so it should be possible to get solutions of all the polynomials in R^3. So there is sth wrong in my understanding or the way that I am thinking of automorphisms as rotations and missing sth.
I thought about whether a splitting field can have 3 dimensions and found that it could. Consider x^3 + 2 = 0 over F. Now it has got 3 roots. 2 complex one real but even the real does not fall in F. So the extension field is (modelling on R^3 ), x-axis is F, y-axis is (2)^1/3 , z complex root.
Rgds
SM
Sumanta said:
Hello,
Now my question.
What? The algebraic closure of R (the field of real numbers) is C (the field of complex numbers).
Since an automorphism on a field is simply an isomorphism from the field to itself, all of those are automorphisms on R3. But how are you making R3 a field? How are you defining multiplication?
Rgds
SM
Hi,
Sorry for the misunderstanding. Yes C is the closure of R. Since I was trying to think geometrically so I thought a similar thing is possible in R^3 vs R.
So if E is not R^3 but say the field generated by the linear combination of the roots the solution of x^3 - 2 = 0. and the field F is Q then will this be true. One can visualize that each of the axes of R^3 will be somehow similar to the field generated by each of these roots. Surely the name suggests that it is a normal extension so this kind of a mental picture intusion is prob OK. Still willing to be proved wrong.
Not sure about the point why if C is a field which is like R^2, then R^3 probably cannot be a field.
  • · Replies 0 ·
  • · Replies 0 ·
  • · Replies 20 ·
