Domain of a Function with Sign Graph
The discussion revolves around finding the domain of the function f(x) = 3/[(x^2 - 4x)^(1/2)], with a focus on using a sign graph. Participants are exploring the implications of square roots and fractions on the domain, particularly regarding conditions for non-negativity and non-zero denominators.
  • Participants express confusion about the concept of a sign graph and its relevance to determining the domain. Some suggest setting the denominator greater than or equal to zero and solving, while others question the correctness of their mathematical steps. There is also mention of a potential misunderstanding regarding the term "sine graph."
The discussion is ongoing, with participants sharing their attempts and clarifying their understanding of the problem. Some guidance has been offered regarding the conditions for the domain, but there is no explicit consensus on the correct approach or interpretation of the sign graph.
Participants are grappling with the definitions and implications of mathematical terms, particularly the distinction between "sign graph" and "sine graph." There is an emphasis on the constraints imposed by the square root and the need for the denominator to be non-zero.
math4life
Find the domain of the function. You will need a sign graph. Answer in interval notation.
f(x)= (3)/[(x2-4x)1/2]
No clue - I don't know how to use a sign graph or what the positive/negative results mean as solutions on a number line.
I am not sure what a sign graph is.
But the domain is the x values for f being defined. There is a square root, so what is inside can't be less than zero. Since it is a fraction, the denominator can't be zero.
Sine graph?
I meant sine graph instead of sign graph. So what do I do? Should I set the denominator to greater than or equal to zero and solve?
I tried solving using the above method but I think my math is wrong. Nonetheless it is wrong because my teacher wants a sine graph on a number line...
1) (sqrt(x2-4x) greater than or equal 0
2) x2-4x greater than or equal 0 (this step is wrong I'm pretty sure - squaring both sides)
3) x2-4x+4 greater than equal 4
4) (x-2)2 greater than equal 4
... ? I still need the sine graph.
I suspect "sign graph" was the correct original intent.
When solving [itex]x^2-4x = x(x-4) > 0[/itex], this boils down to the cases:
[tex]\left\{ \begin{array}{r}{ x > 0 \\ x-4<0} \end{array}[/tex]
[tex]\left\{ \begin{array}{rl} {x<0 \\ x-4 >0} \end{array}[/tex]
This can also be illustrated with a sign graph of x^2 - 4x:
___________________0________4________________
And from this one can determine the domain...
Solving [itex](x-2)^2 > 4 \Rightarrow |x-2| > 2[/itex] is also valid.
--Elucidus
EDIT: Fixed a TeX gaffe.
  • · Replies 21 ·
