Determine if a Sudoku puzzle is easy, medium, hard, or evil
The discussion revolves around determining the difficulty level of Sudoku puzzles (easy, medium, hard, or evil) and the validity of Sudoku puzzles in terms of solvability. Participants explore algorithms for assessing difficulty and the conditions under which a Sudoku puzzle may or may not have a solution.
  • Some participants question whether an algorithm exists to classify Sudoku puzzles by difficulty, suggesting that definitions of "easy," "medium," "hard," and "evil" are necessary.
  • There is a discussion about the definition of a "valid" Sudoku puzzle, with some arguing that it must be solvable and have a unique solution, while others note that puzzles can exist with multiple solutions or no solutions at all.
  • Participants propose that the number of initial numbers given in a puzzle and their distribution may influence its difficulty, with fewer numbers generally leading to harder puzzles.
  • Some participants assert that a puzzle can be valid yet unsolvable if the initial numbers contradict each other or if there are insufficient clues.
  • There are examples provided of configurations that illustrate how certain placements can lead to contradictions, thereby creating unsolvable puzzles.
  • One participant suggests that the complexity of a Sudoku puzzle might be determined by the number of paths to the solution, with fewer paths indicating greater difficulty.
  • Another viewpoint is that the methods required to solve the puzzle may also affect its difficulty, with simpler puzzles allowing for straightforward solving techniques.
Participants express differing views on the definitions of valid and solvable Sudoku puzzles, as well as the criteria for determining difficulty. There is no consensus on a definitive algorithm or method for classifying Sudoku puzzles, and multiple competing perspectives remain throughout the discussion.
Limitations in the discussion include varying definitions of "valid" and "solvable," as well as the ambiguity in determining difficulty without a clear framework or algorithm. The relationship between the number of initial clues and the uniqueness of solutions is also not fully resolved.
jobyts
I can't find a solution to these questions. Can someone help?
1. An algorithm to determine if a Sudoku puzzle is easy, medium, hard, or evil.
2. For every valid Sudoku puzzle, there exist at least one valid solution. True or false? Proof?
Mathematics news on Phys.org
I do not know if there is an answer to (1). In my opinion a Sudoku puzzle is "valid" only when it is solvable. However, less than scrupulous publishers print puzzles with two or more consistent solutions. This just isn't cricket in my book. Any good provider of Sudoku subscribes to the Rule of Uniqueness, that there is exactly one solution to a puzzle.
Does there exist an algorithm to determine if an initial tableau is a valid (and uniquely solvable) puzzle? That I do not know, but would be interested in learning more.
--Elucidus
To elaborate on the second question,
Is there a sudoku puzzle that no solution exists?
if there aren't enough numbers on the grid, then yes, there are unsolvable sudoku puzzles. Like Elucidus said, I assume that if it is a valid puzzle, then it is solvable and not all valid puzzles have unique solutions.
An algorithm for difficulty would probably consist of the number of numbers given and the amount of similar numbers. More difficult puzzles being those that contain less numbers and also less common numbers.
Define "easy", "medium", "hard" and "evil".
Define "valid Sudoku puzzle".
I think that the opposite would be true, if there were too many initial numbers given on the grid then it could be inconsistent (no solution). Not enough initial given numbers is more likely to lead to a multiple possible solution situation.
true
That's the puzzle here. Let's say I created a software program to generate a Sudoku puzzle. Now I need the same software to tell me to tell the difficulty of the puzzle.
By valid, I simply mean, there is no initial numbers that contradict itself (same numbers in the same row/column/box). I define a puzzle with no initial numbers is the one that has the highest number of solutions. When we add initial numbers, the number of solutions reduce. At some point we get only one solution. But can I make it one with no possible solution, by strategically placing the numbers?
With that definition of "valid" then yes there most certainly are "valid" initial numbers which give rise to a puzzle with no solutions.
Here is a trivial example (shows the two upper left cells only, all other cells are blank)
Code:
 1 2   | 3     |
 4 5 6 |       |
 7 8 9 |       |
Another example:
. . . | . 2 1 | . . .
. . . | . . . | . 2 1
. 2 . | . . . | . . .
. 1 . | . . . | . . .
. . 2 | . . . | . . .
. . 1 | . . . | . . .
The number in the upper left corner needs to be both one and 2.
Ah...Thanks uart and MooOfDoom. I should have found it myself :(.
I was trying to think of a possible variation of sudoku - 2 people play, start with no initial numbers, each player adds a number alternately: player A tries to solve the puzzle and win, player B aims to prevent player A from winning.
From your examples, the game seems to be always favoring player B. (I need to think another variation of it.)
As Elucidus asked,
Does there exist an algorithm to determine if an initial tableau is a uniquely solvable puzzle?
The way you rate how hard a sudoku puzzle is by writing a sudoku solver and setting thresholds for the number of lookups it has to do.
Different solver may give different results, so it is still ambiguous.
Moo Of Doom said:
Another example:
would it be like this
2 1 . | . . . | . . .
or this
2 . . | . . . | . . .
1 . . | . 2 1 | . . .
Can a sudoku generator determine the complexity, without trying to solve it?
[EDIT] Probably not. My thinking is as follows.
A puzzle may have different paths to reach the unique solution. The less number of paths means it's a harder puzzle.
Make any sense?
or this
Neither of those are valid, since a row or column contains two 1's.
Not necesarilly. There are several simple methods of checking what the next digits can be (see http://theory.tifr.res.in/~sgupta/sudoku/algo.html for example). Simple puzzle is the one where you can find out each next digit using always the same simple method. More complicated one requires use of different methods in each next step.
Form http://sudokuplace.com/sudoku_scoring.asp:
The primary factor which determines difficulty is the number of cells which can be solved at a given point.
Sounds reasonable.
1. Yes, it can determine the complexity of the sudoku game, but first it need to solve it. Also before solving it, you must "define" the levels: easy, medium, hard, evil etc... Maybe "hard" have two or three valid solutions, "evil" ten etc... Also you may define the level by cycles i.e how many cycles should program made to solve the sudoku game or how much time it needs to solve the game. You got too many factors for defining the levels.
2. One sudoku game could have one, two, three or more solutions, or simply no solution. The prove is in the posts above. :smile:
I find Sudoku puzzles that have more than one solution too be highly irritating (admittedly after several hundred puzzles, this has happened only a few times). I have made a point of only purchasing Sudoku books that state that the puzzles within are uniquely solvable.
Rating the complexity of a puzzle on the number of different solutions it has seems to be inappropriate since a blank puzzle grid has zillions of solutions which are fairly easy to fabricate. Due to my bias against multiple solutions I would reject such a measure - but that's just me.
I would think that the complexity of a puzzle would be determined by the most difficult method involved (and then by how many times it's used). Any Sudoku can be solved by sequential "what if" type tests (a very inelegant way IMO) and is not a very good measure of complexity.
I have solved Sudoku puzzles in a little as 2 minutes, while the hardest took me seven hours. I would be very curious if there were a way to measure the complexity from the intial tableau.
--Elucidus
then what you meant is either 1 or 2 will fit in the top left corner cell
Moo Of Doom said:
Another example:
here's where I misunderstood you :-p
Elucidus,
I remember once doing a sudoku puzzle that had only one solution (given on the back), but at some point while solving it, I had to make a guess somewhere. I redid the puzzle a few times over several days, writing in each possibility in each box that hadn't been ruled out and came to the same "dead end." I tried doing it with the "wrong" guess and it didn't work out, and that was a really disappointing puzzle to me. Have you come across puzzles like this one?
Bohrok said:
Elucidus,
I own a Sudoku book, "Sudoku Master Class" by Tom Sheldon, where each puzzle supposedly is solvable without guessing. So far I have done 34 of the 144 puzzles, all without resorting to guessing (it is one of these that took seven hours). But, yes, early on I would occasionally run into a puzzle where no guesses seemed to work. Invariably I would start over and discover that I had made a minor error early on that lead to an impossible (and incorrect) grid.
--Elucidus
  • · Replies 37 ·
