When the primary of a transformer is connected to A.C. mains
  • Thread starter Thread starter uzair_ha91
    Mains Transformer
The discussion centers on the behavior of a transformer when its primary winding is connected to an alternating current (A.C.) mains supply. Participants explore the implications of an open versus closed secondary circuit, focusing on current flow, power consumption, and the principles of electromagnetic induction involved in transformer operation.
  • Some participants note that when the secondary circuit is open, the primary current is very small, while it increases when the secondary circuit is closed.
  • One participant suggests that when the secondary circuit is closed, the load draws current, prompting a question about the source of this power.
  • Another participant asserts that the power comes from the A.C. generator, referencing the relationship P=IV.
  • It is proposed that if the primary voltage is three times that of the secondary, the secondary current will also be three times that of the primary, with power in equaling power out, neglecting losses.
  • One participant explains that a real transformer consumes power even when there is no load, challenging the notion that output voltage is simply the turns ratio times the input voltage.
  • Another participant describes the electromagnetic principles at play, including the production of magnetic fields by the primary and secondary currents and the effects of Lenz's law on the total magnetic field in the transformer core.
  • A question is raised about the origin of the current in the secondary circuit, with some participants discussing the concept of induced current and voltage.
  • It is clarified that the current in the secondary circuit flows due to the induced voltage when the circuit is closed.
Participants express varying views on the behavior of transformers, particularly regarding power consumption and the relationship between primary and secondary currents. There is no consensus on the implications of these behaviors, and the discussion remains unresolved.
Some limitations include the complexity of real transformer behavior versus idealized models, the dependence on specific load conditions, and the nuances of electromagnetic theory that are not fully explored in the discussion.
uzair_ha91
When the primary of a transformer is connected to A.C. mains, the current in it...
a) is very small if the secondary circuit is open, but
b) increases when the secondary circuit is closed.
PLEASE EXPLAIN THESE FACTS.
What are your thoughts on this?
This http://www.animations.physics.unsw.edu.au/jw/AC.html" .
My thoughts:
When the circuit is closed, the load placed in the secondary circuit draws current...Is that right?
So, where does this power come from?
The power comes from the A.C. generator. (P=IV)
Right. And if the voltage in the primary is 3 times the voltage of the secondary, then the current through the secondary will be three times the current in the primary; and power in = power out (neglecting losses).
When the secondary is open there is no current flow thus it consumes no power, power = voltage*current (there is also an additional term 'power factor' that we can neglect for this example).
When the secondary is attached to a load, the primary coil feeds the secondary power through induction. A voltage is induced onto the secondary coil in the amount equal to the ratio of secondary windings/primary windings. The power required by the secondary comes from this voltage.
A real transformer does consume power with no load.
The output voltage is not the ratio of the turns x the input voltage for a real transformer... certainly not with with more than just a very light load on it.
As you said when the secondary is open the primary current is very small; when the secondary is closed current flows in it and the primary current increases.
To understand what is going on you should have some knowledge of electromagnetic fields and Lenz's law.
When curren is flowing through any conductor a magnetic field is produced. Now, when a curren is flowing through the primary winding of a transformer the produced magnetic field is flowing in the iron core of the transformer. In this case the magnetic field isrepresented by lines known as flux lines. This lines intersect the secondary winding and induce a voltage across it.
http://www.clayeng.net/Training/myweb6/Module04/Output/images/t-f3.gif
A) Secondary is open:
No current flows through the secondary and consequently there is no magnetic field produces by the secondary. The only field in the core is that due to the primary current (which is small).
B) Secondary is closed:
Current is flowing through the secondary and a magnetic field is produced (so, now there are two magnetic fields: from Primary and Secondary). The secondary magnetic field opposes the primary magnetic field according to Lenz's law. So, the total magnetic field in the core which is now the resultant of primary and secondary magnetic fields is reduced. Since, EMF = N dф/dt , by reduction of flux the induced emf in the primary winding is reduced causing more current to flow in the primary winding. This continues until a balance is achieved.
Firstly, it seems to be complicated... but it isn't.
You said that when the secondary circuit is closed, a current flows through the circuit which produces its own magnetic field. From where does this current come from? I thought that it is the induced current that flows through the secondary circuit. (Induced when the primary current being AC fluctuates between positive and negative peak emfs and causes change of flux to occur through the secondary coil)
The current flows because there are an induced voltage across the secondary winding.
There are voltage...by closing the circuit there will be current.
What do you mean by Induced Current?
If you mean the current flowing due to the induced voltage, you are right.
Induced voltage causes the induced current to flow.
  • · Replies 81 ·
9K
