Why doesn't the electron have a definite position?
  • Context: Graduate
  • Thread starter Thread starter mahela007
    Electron Position
The discussion revolves around the question of why electrons do not have a definite position, exploring concepts from quantum mechanics such as wave-particle duality and the Heisenberg uncertainty principle. Participants examine the implications of these principles on the understanding of electron behavior in various contexts, including theoretical and conceptual frameworks.
  • Some participants suggest that if an electron were given a definite position, it would contradict its wave nature.
  • One participant explains that determining an electron's precise position requires knowing multiple parameters simultaneously, which is physically impossible due to the Heisenberg uncertainty principle.
  • Another viewpoint posits that electrons can have a definite position only when their energy is completely undefined, highlighting the complexities of quantum mechanics.
  • It is noted that the Schrödinger equation leads to the interpretation of electrons as probability densities rather than real particles with definite positions and momenta.
  • A participant mentions that attempting to locate an electron within a region the size of its Compton wavelength would necessitate high-energy measurements that could create electron-positron pairs, complicating the measurement process.
  • Some participants discuss the concept of a probability wave, suggesting that while an electron does not occupy a specific location until measured, its wave function provides a likelihood of finding it in various locations.
  • There is a consideration of the discrete energy levels of electrons, particularly when they are bound to atomic orbitals, which adds another layer to the discussion of their positions.
Participants express a range of views on the nature of electron positions, with no consensus reached. While some agree on the implications of the uncertainty principle, others propose different interpretations of quantum mechanics and the behavior of electrons.
The discussion reflects limitations in understanding the implications of quantum mechanics, particularly regarding the definitions of position and momentum, and the complexities involved in measuring quantum states.
mahela007
I have understood that an electron can be thought of both as a wave and as a particle. But I still don't understand why we can't give it a definite position...
Well if we gave it a definite position, then it wouldn't really be a wave?
Hi there,
Try to imagine (classically) the speed of an electron around a nucleus. Now to find out precisely the position of the electron, you would need to know so many different parameters at the same time, that it becomes physically impossible to do so.
From the Heisenberg uncertainty,[tex]\Delta x \times \Delta p \geq \frac{h}{2}[/tex] fixes the precision of the position. If you decide to be super-duper precise on the position, then you have absolutely no-more clue about it speed. Therefore, you will not be able to keep track for very long of the "exact" position.
Cheers
Actually, in the QM description electrons can in fact have a definite position, however only when they are in such a state that the energy is completely undefined.
As fatra2 states, it has to do with the Heisenberg uncertainty.
Without diving into the math, you could say that it is simply a result of the formulation of QM, which leads to the question of "How fast was the electron going when it was at x" becoming utter nonsense. It's kinda like the joke
"If it takes two men two hours to dig a hole, then how long would it take one man to dig half a hole?"
Per definition, there is no such thing as half a hole, therefore the question makes no sense. Similarly in QM where you describe an electron with a wavefunction, there is no such thing as a simultaneous position and velocity (or energy).
Unless we make new theory replacing the Schrödinger equation, all we can do is only believing the uncertainty principle. (even if the uncertainty principle seems strange to us.)
Some people may dream of treating the electrons as real particles based on the Schrödinger equation, but these methods won't work.
If we try to treat the electrons as real particles (with definite momentum and position),
we must forget the idea of the Schrödinger equation.
At first Schrödinger thought that the electron is wave (and a particle).
But the wave packets will be spreading in all space with time (this means the electron will become bigger and bigger with time.)
So, later he changed his idea, and he thought the wave(function) means the probability density
of the electron.
Also, from to the uncertainty relation it follows that trying to locate an electron to within a region the size of the Compton wavelength would require measurements at such high energies that electron-positron pairs would be created. Then, there is no way to know which electron's position you need to measure, as all electrons are exactly identical.
Thanks for the replies... they all helped.
So let me sum up to see if I got it right.
The electron is buzzing around and we have no way of predicting where it will be because of a fundamental law of nature (the uncertainty principle). The electron can be at any place given by it's wave function... (right?)
One final question:
Although we can't exactly "find" the electron, does it have a position in space? Logically, it seems that it should. (my logic has been known to be faulty.)
One final question:
I think it is more along the lines of this:
We do have a way of "predicting where it will be"; there is a probability wave, which tells us the likelihood of finding it in a specific "location", but it does not actually occupy that "location" until we measure the position (collapsing the probability wave). The more precisely one measures the position, the less one knows about the momentum.
In fact, it is important to keep in mind that electrons have discreet energy levels, which is especially relevant when they are bound to an orbital around a nucleus.
"but it does not actually occupy that "location" until we measure the position (collapsing the probability wave)." .
But the instant we look at the electron, it's path is disturbed... thanks .. I think I'm getting to understand what all this is..
However, I won't mark this thread as solved just yet. If anyone else has any ideas, please post them here...
  • · Replies 44 ·
