Attractive Forces: Delta V, E', and E0 Explained
  • Context: Graduate
  • Thread starter Thread starter Niles
    Forces
The discussion clarifies the relationship between the unperturbed energy (E0) and the perturbed energy (E') in quantum systems, specifically when delta V = E' - E0 < 0, indicating an attractive force. The example of two neutral, polarizable atoms illustrates how the electrostatic interaction leads to a negative perturbation, resulting in a decrease in total energy as the atoms approach each other. This interaction is quantitatively described by the van der Waals force, which is proportional to the inverse sixth power of the separation distance between the atoms.
  • Understanding of quantum mechanics concepts, specifically ground state energy.
  • Familiarity with perturbation theory in quantum systems.
  • Knowledge of electrostatic interactions and potential energy.
  • Basic grasp of van der Waals forces and their mathematical representation.
  • Study perturbation theory in quantum mechanics for deeper insights.
  • Explore the mathematical derivation of van der Waals forces.
  • Learn about the implications of attractive forces in quantum systems.
  • Investigate the role of polarizability in atomic interactions.
Students and researchers in quantum mechanics, physicists studying atomic interactions, and anyone interested in the principles of perturbation theory and attractive forces in quantum systems.
Niles
Hi
The unperturbed energy of the ground state a quantum system is denoted E0. Now the perturbed energy of the ground state of the same quantum system is denoted E'.
If we have that delta V = E' - E0<0, then my book says that the perturbation is an attractive force.
Why is that?
It depends on how exactly "force" is defined. Suppose the strength of the perturbation is controlled by a physical degree of freedom. E.g. consider two atoms at some distance d, and take the perturbation to be the electrostatic interaction between the two atoms. If d is infinite you have the unperturbed Hamiltonian, and the smaller you make d, the larger the perturbation becomes. If the perturbation to the energy is negative, then that means that the total energy of the atoms held at rest would become less if you were to move them closer.
If the atoms can move freely, then due to conservation of energy their kinetic eergy would have to increase. So, the "total energy at rest" gives you the effective potential energy and minus the gradient of that is the force.
It arises when looking at two neutral, polarizable atoms. Here we show that the perturbation (the Coulomb interaction between the atoms) causes an attractive potential proportional to the inverse sixth power of their separation.
This is the van der Waals interaction.
What I cannot understand is, why delta V = E - E0 (see first post) implies an attractive force.
  • · Replies 49 ·
