Finding Domain and Range of Functions
The discussion revolves around finding the domain and range of the function y=sin²x. Participants are exploring the properties of the sine function and its transformations, particularly focusing on how squaring affects the output values.
  • Participants discuss the domain of the sine function and its implications for sin²x. There are questions about the range, particularly concerning the minimum and maximum values of the function. Some participants express confusion about the relationship between the sine function and its squared form.
The discussion is active, with participants offering insights and questioning each other's reasoning. Some guidance has been provided regarding the properties of the sine function, but there is still uncertainty about the range and the implications of squaring the function.
There is some confusion regarding the interpretation of the domain and range, particularly in relation to the values that sin²x can take. Participants are grappling with the implications of the function being a perfect square and its effect on the minimum value.
MorganJ
Find the domain and range of y=sin^2x
I have a hard type computing this into my graphing calculator. Can someone help in the steps to find the domain?
y=sin2x=(sinx)2.
since it is squared it is never negative. The domain should be easy to find, given your knowledge of y=sinx
So the domain would be 0 less than or equal to positive infinity? and the range would be the same?
What is the domain of sin(x)? The range is the values of 'y' that the graph lies between.
You know that -1≤ sinx ≤ 1, so where would sin2x lie between?
the domain of sin (x) is -∞ < x < ∞ and would sin²x lie between -2 ≤ x ≤ 2...sorry i am bit confused.
Right, sin2x has the same domain as sin(x)
and would sin²x lie between -2 ≤ x ≤ 2...sorry i am bit confused.[/QUOTE]
if y=sin2x, what is it's maximum and minimum value?
Wouldn't its maximum value be 1 and the minimum value be -1?
yes
remember, sin2x = (sinx)2 so it is a perfect square, meaning sin2x ≥ 0 . So what's the minimum value going to be?
So...would it be 1 as well?
no
in y=x2, what is the lowest value of y which gives a real value for x?
I have no clue, honestly. I am graphing it on my calculator. Would it be zero? I do not think the minimum value is a negative number.
yes it would be zero.
Okay so the domain would be -∞ < x < ∞ and the range is 0 ≤ y ≤ 1 ?
That should be correct. You could write [itex]x \epsilon \Re[/itex] as well I believe.
Okay. Thank you so much for helping, rock.freak667. I really appreciate it :-)
