Explaining the Constant Speed of Light in Special Relativity: A Beginner's Guide
The discussion revolves around the constancy of the speed of light in the context of special relativity. Participants explore the implications of this constancy for different reference frames and seek to clarify the conceptual challenges faced by beginners in understanding these principles.
  • One participant expresses difficulty in explaining to a friend why light travels at speed c even when they are moving at 0.8c alongside it, suggesting that this creates a conceptual challenge.
  • Another participant proposes using examples of relativistic velocity addition to help illustrate the concept, including cases where the projectile has speeds equal to or less than c.
  • A different participant emphasizes that it does not make sense to claim one can travel alongside a beam of light, suggesting that in the observer's frame, the photon emitted travels at c.
  • One participant states that the constancy of c is an observed phenomenon and axiomatic in relativity, leading to different measurements of time and distance by different observers.
  • Another participant notes that their friend's confusion stems from an assumption of "real" motion, indicating a need for deeper explanation of the theory.
  • A historical perspective is provided, referencing Maxwell's equations and the subsequent experiments by Michelson and Morley, which sought to find variations in the speed of light but did not succeed.
Participants express varying levels of understanding and approaches to explaining the constancy of the speed of light, with no consensus on a singular explanation or resolution to the conceptual difficulties presented.
Some participants highlight the limitations in understanding due to assumptions about motion and reference frames, as well as the historical context of the development of these concepts in physics.
s1cko
I apologize if this has been covered but I did a quick search and didn't see anything.
Alright, my question concerns the speed of light and why it's a constant. I was trying to explain special relativity to my friend and after I told him that the speed of light is always c no matter what reference frame you are in he seemed troubled by the idea. He gave me an example of how this could not be, here is what he said: "alright say light and I start at the same point and I'm going .8c along side it, you're meaning to tell me that light is still going c even though it should be going .2c?" I simply said yes, he asked why. I tried to say that the speed of light has to be constant so no reference frame was special and every reference frame in uniform motion is good for doing physics. He still went back to his example though, it's actually a pretty solid argument. I'm new to relativity so I'm having trouble explaining to him. Can someone help me explain this?
jtbell said:
Maybe working out a few examples of relativistic velocity addition for him will help. Include cases where the "projectile" has v = c and v < c.
Thanks for that link, its very useful. Though his problem lies in the concept. The problem is that it is hard conceptually to come to terms with the fact that if you and light both start at the same time and you are moving at half the speed of light that light is still moving at point c. I truly do not know how to answer his question. Is what I already told him the correct answer? Is there a better way to put it?
Well, it really doesn't make much sense to say you're traveling "along side" a beam of light.
If you and light truly start at the same point, I'm assuming you emit a photon from, say a flash light you're holding in your hand at a given time. Now, you may be moving at .8c with respect to a nearby planet or something (some outside reference frame) but surely your friend will agree that in YOUR frame, where you are motionless, the photon travels away at c. If he's concerned about the other frames, see jtbell's post.
There is really no "why" to the constancy of c; it is an observed phenomenon and axiomatic (an assumed fact) in Relativity. All this other stuff is the set of consequences of that fact. Because c is constant, different observers' clocks and meter sticks end up measuring completely different things (different observers disagree on what interval a "second" of time or a "meter" of distance represent), and the differences in these clocks and meter sticks conspire to keep c constant.
I thought I was explaining it right. Thank you guys for all of your help. He's having trouble because he's still assuming something has a "real" motion. He thinks he is "really" moving at speed .8c. Ill keep trying to explain more of the theory and make him understand.
I like to blame Maxwell. This all started in 1867 when Clerk Maxwell cast the basic relationships of electromagnetism in the form of a wave equation. In the place of the velocity of the wave was the expression:
[tex]\frac 1 { \sqrt { \epsilon_0 \mu_0 }}[/tex]
Where [itex]\epsilon_0[/itex] is the permittivity of free space and [itex]\mu_0[/itex] is the permeability of free space. When Maxwell computed the value of this constant he was amazed to find a number equal to the measured value of the speed of light. This was the start of the "schism" in physics, which lasted until Einsteins work in 1905.
Many felt that Maxwell had errored and assumed that the error would be found. Michelson and Morly did their famous experiment shearching for a variation in the speed of light corresponding to the variation in the Earth's velocity over the year. They were unable to find any
  • · Replies 19 ·
  • · Replies 18 ·
  • · Replies 33 ·
  • · Replies 64 ·
  • · Replies 45 ·
