How does \sqrt{1+((x^2)/(4-x^2))} simplify to 2 times\sqrt{1/(4-x^2)}?
The discussion revolves around the simplification of the expression \(\sqrt{1+\frac{x^2}{4-x^2}}\) and how it relates to the form \(2\sqrt{\frac{1}{4-x^2}}\). The subject area is algebra, specifically focusing on manipulating square roots and fractions.
  • Exploratory, Mathematical reasoning, Problem interpretation
  • The original poster attempts to simplify the expression but struggles to see the connection to the proposed simplified form. Some participants suggest finding a common denominator and rewriting the expression to facilitate simplification. Others provide hints about rewriting the number 1 in a specific form to aid in the process.
Participants are actively engaging with the problem, offering hints and suggestions for rewriting the expression. There is a mix of approaches being discussed, but no explicit consensus has been reached regarding the simplification process.
There are indications that the original poster may be constrained by the need to adhere to specific algebraic rules or methods typically taught in homework contexts, which could be influencing their approach to the problem.
Waggattack
1.I can't figure out how the [tex]\sqrt{1+((x^2)/(4-x^2))}[/tex] simplifies to 2 times[tex]\sqrt{1/(4-x^2)}[/tex]
I have tried rewriting it in different ways, but I can't see how it simplifies. [tex]\sqrt{x^2 + 1/4-x^2}[/tex]
The first thing to do is find a common denominator. Then you will be able to zero out some terms. Then, using the property of a square root, the square root of a fraction is the same as the square root of the numerator over the square root of the denominator. This will give you the answer.
Waggattack said:
[tex]\sqrt{1+((x^2)/(4-x^2))}[/tex] simplifies to 2 times [tex]\sqrt{1/(4-x^2)}[/tex]
It may help to rewrite these in a form where you don't need the parentheses.
[tex]\sqrt{1+{{x^2}\over{4-x^2}}}[/tex] simplifies to [tex]2\sqrt{{{1}\over{4-x^2}}}[/tex]
Does that make it easier?
Hint: 1 in the square root, [tex]1=\frac{4-x^2}{4-x^2}[/tex]
In other words, write
[tex]1+\frac{x^2}{4-x^2}[/tex]
as
[tex]\frac{4- x^2}{4- x^2}+ \frac{x^2}{4- x^2}[/tex]
and add the fractions.
  • · Replies 17 ·
