Can Relativity be Applied to the Motion of Atoms and Intermolecular Forces?
The discussion explores the application of relativity to the motion of atoms and intermolecular forces. Participants question whether relativistic effects, such as time dilation, are significant at the atomic level and how macroscopic averaging might influence these effects.
  • Some participants propose that time may move slower for an atom that is accelerating relative to another atom, while questioning if macroscopic averaging would negate this effect.
  • One participant argues that velocity is the determining factor for relativistic effects, suggesting that molecules moving faster due to heat experience less proper time compared to a stationary lab frame.
  • A hypothetical scenario is presented where heating a radioactive isotope to relativistic velocities could prolong its half-life, though practical containment of such a plasma is noted as a challenge.
  • Another participant mentions that relativistic effects are indeed present at the atomic scale, particularly in high atomic orbitals, and references the need for relativistic corrections in these cases.
  • It is noted that while relativistic considerations can apply to a collection of atoms, the non-relativistic approximation is often sufficient due to the relatively low speeds of atoms in many contexts.
Participants express a range of views on the relevance and significance of relativistic effects at the atomic level, indicating that multiple competing perspectives remain without consensus.
There are unresolved assumptions regarding the conditions under which relativistic effects become significant, as well as the interplay between relativistic and quantum mechanical considerations in atomic systems.
avocadogirl
Can you think about relativity in terms of the motions of atoms as they are subject to intermolecular forces? Is time moving slower for the atom which is accelerating with respect to another? Or, would the macroscopic averaging negate the individual motion of the atoms?
Or, is this a ridiculous question to be asking?
The determining factor is velocity. When an object is hot the molecules it consists of move faster. The molecules in the highest accuracy time measuring devices are cooled to close absolute zero. (The main reason for that, I think is to make the spectrum as narrow as possible)
Acceleration of molecules relative to each other does not elicit relativistic effects; it's relative velocity that counts. When molecules in a sample have (averaged over time) a larger velocity than the lab it is located at, then for those molecules less proper time will elapse than for the lab.
A very, very farfetched scenario (but in principle possible):
You have a sample of a radio-active isotope with a short half-life, and you want to prolong the life of the sample. Heat it up to plasma temperature and beyond, and if you get it so hot that the nuclei reach relativistic velocities the life will be significantly prolonged. Containing that plasma might be tricky, though.
Cleonis
There are relativistic effects at the atomic scale, but not in ways that you are thinking of. Relativistic corrections for high atomic orbitals, such as the d and f orbitals, are routinely considered. Furthermore, why do you think http://math.ucr.edu/home/baez/physics/Relativity/SR/gold_color.html" ?
Zz.
Absolutely you can think about relativity when looking at a collection of atoms that feel forces (you *generally* have to also deal with quantum mechanics too). Anyway, even if a macroscopic object is just sitting on a table, the atoms are moving with respect to each other, so they will indeed each have their own Lorentz frame: They will not generally agree on distance and time measurements of events they might witness, which includes seeing time dilation. However, as mentioned in the previous post, the non-relativistic approximation is often good enough for these situations because the relative speeds of the atoms are not high enough. Inside the atom, relativistic effects become very important, though.
  • · Replies 23 ·
  • · Replies 20 ·
  • · Replies 36 ·
  • · Replies 20 ·
  • · Replies 35 ·
