Calculating Shear Stress on a Rivet in Tension with Angle of Load
The discussion focuses on calculating shear stress on a rivet subjected to a 5kN load at a 60-degree angle. The rivet has a diameter of 20mm, and the load's angle relative to the rivet axis is 30 degrees. To determine the tensile shear stress, participants emphasize the importance of applying trigonometric functions, specifically using sine to resolve the load components. The correct approach involves calculating the shear stress using the formula for shear stress and incorporating the angle of the load.
  • Understanding of shear stress calculations
  • Familiarity with trigonometric functions
  • Knowledge of rivet mechanics
  • Basic principles of load distribution in structural engineering
  • Study the formula for calculating shear stress in rivets
  • Learn about the application of trigonometry in engineering mechanics
  • Explore the effects of load angles on structural components
  • Review case studies involving rivet connections under tension
Structural engineers, mechanical engineers, and students studying mechanics of materials will benefit from this discussion, particularly those focused on rivet design and load analysis.
Stacyg
A load of 5kN is applied to the tensile member shown in the figure below and is carried at the joint by a single rivet of 20mm diameter. The angle of the joint is 60 degrees to the axis of the load (the axis of the rivet is at 30 degrees to the line of action of the load P). Calculate:
(a) the tensile shear stress in the rivet
(b) shear stress in the rivet
The figure is attached. I know how to calculate the stress but I'm not sure how to calculate it on an angle like this. I'm guessing you use the same equation and maybe times it by 5sin60 or do i use 30.
Thanks Stacy
For shear stress, one of the answers you listed is correct. You just need to use trigonometry to determine which one is correct.
11K
