Why does a compass needle point downwards at the magnetic north pole?
A compass needle points downwards at the magnetic north pole due to the vertical component of the Earth's magnetic field. At this location, the magnetic field lines converge and point directly into the Earth, causing the compass needle to tilt downward instead of remaining horizontal. This phenomenon occurs because the horizontal component of the magnetic flux is negligible at the magnetic north pole, resulting in a predominance of the vertical component.
  • Understanding of Earth's magnetic field
  • Basic knowledge of compass mechanics
  • Familiarity with magnetic flux concepts
  • Awareness of geographic versus magnetic poles
  • Research the Earth's magnetic field structure and behavior
  • Explore the differences between geographic and magnetic poles
  • Study compass calibration techniques for accurate navigation
  • Investigate the implications of magnetic declination in navigation
Geographers, navigators, educators, and anyone interested in understanding the principles of magnetism and navigation.
poojarao
A compass needle held horizontally is only afftected by the horizontal component of the magnetic flux. What do you think will happen to a compass needle at the magnetic north pole?
Which way do the magnetic field lines go at the magnetic north pole if you stand there?
  • · Replies 31 ·
