Taking Derivative of Av-2exp(s/R): Solve Tds-Pdv
  • Thread starter Thread starter avocadogirl
    Derivative
The discussion focuses on deriving the equation for a system defined by u = Av-2exp(s/R) to express it in the form du = Tds - Pdv. The key equations used include the relationships du = ∂u/∂s ds + ∂u/∂v dv, ∂u/∂s = T, and ∂u/∂v = -P. Participants clarify that the partial derivative of exp(s/R) with respect to s yields 1/Rexp(s/R), while the partial derivative with respect to v is zero due to (s/R) being constant. The final goal is to express the energy change in terms of temperature and pressure.
  • Understanding of partial derivatives
  • Familiarity with thermodynamic equations
  • Knowledge of exponential functions and their derivatives
  • Basic principles of energy, temperature, and pressure relationships
  • Study the application of partial derivatives in thermodynamics
  • Learn about the total differential and its significance in energy equations
  • Explore the implications of constant variables in thermodynamic systems
  • Investigate the relationship between temperature, entropy, and pressure in thermodynamic processes
Students and professionals in thermodynamics, particularly those studying energy systems, as well as anyone involved in solving complex equations involving temperature and pressure relationships.
avocadogirl
I have a system that is defined by the equation:
u = Av-2exp(s/R)
I'm looking for the final temperature of the system knowing that as the system changes, pressure will be halved and (s/R) will be a constant.
The equation which relates energy, temperature, and pressure is du = Tds - Pdv
How do I take the derivative of Av-2exp(s/R) to get it in the form Tds - Pdv?
[tex]\partial[/tex]u[tex]\partial[/tex]s=T
[tex]\partial[/tex]u[tex]\partial[/tex]v=-P
du = [tex]\partial[/tex]u[tex]\partial[/tex]s ds + [tex]\partial[/tex]u[tex]\partial[/tex]v dv
Do I take the partial derivative of the whole thing for v, then add another term that is the partial derivative of the whole thing for s?
-2Av-3exp(s/R) + partial derivative for exp(s/R) with respect to s = du?
And, when you're taking the derivative of exp(s/R), does it come out something like: 1/Rexp(s/R)?
I think what you're looking for is what's called the total differential, du.
In your problem,
[tex]du = \frac{\partial u}{\partial s}~ds~+~\frac{\partial u}{\partial v}~dv[/tex]
Starting with u = Av-2es/R, take each partial derivative and substitute it into the preceding formula.
It depends on which partial you're taking. If you take the partial of u w.r.t s, yes, that's right. If you're taking the partial of u wrt v, though, it doesn't. That partial is 0, since es/R is a constant as far as v is concerned.
Thank you.
