The mixture of two gases in gravitational field
The discussion revolves around the behavior of two ideal gases mixed in a box of infinite height within a constant gravitational field. Participants explore the molar concentration of each gas as a function of height, considering factors such as entropy of mixing and the equations of state. The scope includes theoretical reasoning and mathematical modeling related to gas behavior under gravitational influence.
  • One participant poses a problem regarding the molar concentration of two gases in a gravitational field, noting the complexity introduced by mixing entropy.
  • Another participant suggests a method to derive the total density as a function of height, using the equation of state and relating it to the total molar mass.
  • A correction is made regarding the notation for total molar mass, clarifying that it should depend on the molar concentrations of each gas.
  • Further clarification is provided on the equations governing the behavior of each gas constituent, emphasizing the need to consider individual pressures and densities.
  • One participant expresses uncertainty and suggests seeking additional input from others in the forum.
  • Another participant acknowledges an initial mistake in their response and offers further guidance on the approach to take.
Participants do not reach a consensus on the approach to solving the problem, as there are multiple interpretations and corrections regarding the equations involved. The discussion remains unresolved with competing views on how to proceed.
There are limitations in the discussion, including unresolved mathematical steps and dependencies on specific definitions of variables. The complexity of the entropy of mixing and its incorporation into the equations is also noted but not fully addressed.
paweld
Two ideal gases are mixed in the box of infinite height placed in constant gravitational field.
There are [tex]n_1[/tex] moles of the first gase and [tex]n_2[/tex] moles of the second. Their
molar mases are [tex]M_1[/tex] and [tex]M_2[/tex] respectively. Let's assume that the
temperature is constant. What's the molar concentration as a function of height of each gas.
If in the box was only one gas the answer would be simple but when there are two different
types of molecules we have to take into consideration the entropy of mixing. That's the
problem because I don't know any formula that might be easily incorporated into differential
equations.
Science news on Phys.org
Try the following.
First write the total density as a function of height. You get this solving
[tex] \partial p_{total} / \partial y = \rho_{total}(y) g<br /> [/itex]<br /> (using the equation of state [itex]p_{total}=\rho_{total} R T / M_{total}[/itex])<br /> where [itex]M_{total}[/itex] is the total molar mass.<br /> Then write the total pressure as a function of height. Each of these expressions will have an unknown pre-factor.<br /> <br /> Next write <br /> [tex] \rho_{total} = N_1 M_1 + N_2 M_2[/tex]<br /> [tex] p_{total} = RT (N_1 + N_2)[/tex]<br /> where [itex]N_1[/itex] and [itex]N_2[/itex] are molar concentrations.<br /> <br /> You have two equations and two unknowns [itex]N_1[/itex] and [tex]N_2[/itex] which you can solve. <br /> <br /> Finally you can obtain the pre-factors by using the information given about the total amount of stuff you have. You will have to integrate your concentrations with respect to height and set them equal to [itex]n_1[/itex] and [itex]n_2[/itex].[/tex][/tex]
Correction.
Instead of [itex]N_{total}[/itex] for the total molar mass I meant to write [itex]M_{total}[/itex] and I was unable to edit it for some reason.
loveequation said:
Correction.
What exactly do you mean by [itex]M_{total}[/itex]. It should depend on [itex]N_{1}(y)[/itex] and [itex]N_{2}(y)[/itex] ([tex]M_{total} = (N_1(y) M_1+N_2(y)M_2)/(N_1(y)+N_2(y))[/tex]).
So in fact there is only one equation:
[tex] \frac{\partial \left( R T (N_1(y)+N_2(y)) \right)}{\partial y} = g (N_1(y) M_1 + N_2(y) M_2 )[/tex]
Let me think about it. In the meanwhile you might want to re-post it to see if others can be of more immediate assistance.
I think you have to write for each [itex]i[/itex]th constituent of the gas
[tex] \frac{\partial p_i}{\partial y} = -\rho_i(y)g[/tex]
and use the equation of state [itex]p_i = \rho_i R T/m_i[/itex] where [itex]m_i[/itex] is the molecular mass. Note that the molar density [itex]N_i = \rho_i/m_i[/itex].
I assume you can do the rest. If not let me know.
I apologize for the initial wrong answer.
