Proving (a^n -b^n) Does Not Divide (a^n + b ^n): Divisibility Question
  • Context: Graduate
  • Thread starter Thread starter joeblow
    Divisibility
The discussion revolves around the question of whether the expression (a^n - b^n) divides (a^n + b^n) for all integers a, b, and n. Participants explore various approaches to proving or disproving this divisibility, considering different cases and assumptions.
  • One participant suggests that if (a^n - b^n) divides (a^n + b^n), it leads to a condition involving the greatest common divisor of b and a^n.
  • Another participant emphasizes the need to assume that a, b, and n are all greater than 1 to avoid counterexamples.
  • Some participants discuss the implications of the divisibility condition, leading to the conclusion that if a >= b, it must imply a = b.
  • A participant proposes reducing the problem to the case where a and b are relatively prime.
  • Counterexamples are provided to challenge the universality of the claim, such as specific values for a, b, and n.
  • There is a discussion about the implications of the equations derived from the divisibility condition, with some questioning the correctness of specific transformations.
  • One participant acknowledges a proof that appears correct but notes a potential typo regarding the divisibility of b by 2.
  • Another participant raises a concern about whether the derived conditions imply equality between the expressions.
Participants express differing views on the conditions under which the divisibility holds, with some arguing for specific cases and others providing counterexamples. The discussion remains unresolved, with multiple competing perspectives on the validity of the divisibility claim.
Participants highlight the importance of assumptions regarding the values of a, b, and n, as well as the implications of common factors. There are unresolved mathematical steps and transformations that contribute to the complexity of the discussion.
joeblow
How can I show that (a^n -b^n) doesn't divide (a^n + b ^n) for all integers a,b, and n?
I have that if (a^n -b^n) did divide (a^n + b ^n), then (a^n +b^n) = q (a^n -b^n) which implies b^n = -q*b^n (mod a^n). Then 1 = -q (mod a^n), meaning gcd(b, a^n) = 1. I am unsure of what more I can deduce. Any help is appreciated.
I think you need to assume that a, b and n are all > 1. Otherwise there are simple counterexamples.
Yes, of course.
a^n - b^n | a^n + b^n
implies
a^n - b^n | 2b^n
and so, if a >= b,
ka^n = (2 - k)b^n
for some positive k. It must be the case that k = 1 (why?), so
a^n = b^n
and hence
a = b.
implies
a^n - b^n | 2b^n
and so, if a >= b,
ka^n = (2 - k)b^n
a^n = b^n
and hence
a = b.
Shouldn't the equation
ka^n = (2 - k)b^n
instead be
ka^n = (2 + k)b^n?
I think I have a solution. Here's a hint: Prove that you can reduce the problem to the case in which a and b are relatively prime.
HTH
Petek
We assume a and b have no common factor, because if they did, it could be removed.
To avoid the case of a^n-b^n = 0, we need only consider a prime p, such that p divides a^n-b^n. We eliminate the trivial cases where n=1, or where a,b or n =0. Then [tex]a^n \equiv b^n Mod p[/tex]; [tex]a^n + b^n \equiv 2b^n Mod p[/tex]
Thus p divides 2 or p divides b^n. but 2 can be a factor of b since then it would also divide a, and consequently we can chose p >2. But then it follows both a and b are divisible by p contrary to assumption.
That is easy.
a=3,b=2,n=2 implies
a^n+b^n=13 which is not divisible by a^n-b^n=5.
So, if it is not valid for 3,2,and 2, then it is not valid for all integers.
implies
a^n - b^n | 2b^n
Hm, if a^n+b^n=2b^n doesn't it mean a^n-b^n=0?
This proof seems to be correct (with "but 2 can be a factor of b" an obvious typo for "but 2 cannot be a factor of b"), and is simpler than the one I had in mind. Nice!
Petek
Petek
Yes, thank you: "But 2 CANNOT be a factor of b since then it would also divide a..."
an-bn|an+bn
Then
an - bn|an+bn-(an-bn)
Which gives
an-bn|2bn
Nothing here says they're equal though
Thanks :smile:
  • · Replies 21 ·
  • · Replies 25 ·
  • · Replies 33 ·
