What's the Acceleration of an Object at Its Highest Point?
The discussion revolves around determining the acceleration of an object at its highest point in a projectile motion scenario. The original poster presents initial conditions including velocity components, height, and time of flight, expressing confusion about which values to use in their calculations.
  • Exploratory, Conceptual clarification, Problem interpretation
  • Participants discuss separating motion into x and y components and question which initial velocity to use for calculations. There is a focus on understanding the relationship between vertical and horizontal velocities at the highest point.
The discussion is ongoing, with participants providing guidance on how to approach the problem by emphasizing the importance of treating horizontal and vertical motions separately. Clarifications about the nature of the ball's velocity at its highest point are being explored.
There is uncertainty regarding the application of formulas and the interpretation of initial velocity components. The original poster seeks clarification on the values to use in their calculations, indicating a need for further exploration of the concepts involved.
maegenr8
I need to find the acceleration of the object at its highest point?? I thought it would be zero, but that is wrong.
-The initial velocity is 26 m/s at 54 degrees above the horizontal axis.
-it's initial horizontal velocity is 15.3 m/s and vertical is 21.0 m/s (is this acceleration?)
-It reaches a height of 22.6 meters
-in 2.15 seconds
-the balls velocity at its highest point is 15.3 m/s
What's the balls acceleration at its highest point?
For how long a time is the ball in the air?
When the ball lands on the court, how far is it from the place where it was hit?
Please explain. I'm not sure which values to use for initial velocity, etc. when I use the formulas.
I thought I should use the velocity-time equation. final velocity=initial velocity + acceleration*time
I did 15.3= 26+ 2.15a but the answer was incorrect.
What am I doing wrong?
The main thing you need to do is keep you dimensions separate. Work out the equation for all motion in the x plane. Then work out the equation for all motion in the y plane. Try this out first.
when working it for the values in the x plane would i just use 15.3 as initial velocity or the 26?
You would use the 15.3 because that is the x component of the velocity.
okay, 15.3 is the velocity at the balls highest point. is that because it's vertical velocity at its highest point is zero (because at that instance its not going up or down) but it is still moving horizontally and that's why it's 15.3?
I'm a bit confused by what you are saying. You are correct that the vertical velocity of the ball at its highest point is zero and that the horizontal velocity at its highest point is 15.3, but you need to be more specific when stating the ball's velocity
