Stuntman jumping 2D kinematics.
The problem involves a stuntman jumping from one building to another, analyzing his 2D kinematics during the flight. The flight duration is specified, along with the initial speed and angle of the jump, as well as the height difference between the two buildings.
  • Participants discuss the kinematic equations relevant to the problem, particularly focusing on the vertical displacement equation and the initial vertical position. There is an attempt to relate the vertical and horizontal components of the motion.
Some participants have provided guidance on correcting the initial vertical position in the equations. There is an ongoing exploration of how to properly set up the equations to find the initial velocity and the displacements involved.
Participants are considering the implications of the height difference between the buildings and how it affects the calculations. The discussion reflects on the initial conditions and the need for clarity in the setup of the problem.
CandyApples
A stuntman is jumping from building A to building B. His flight lasts 1s. He leaves point A with a speed of Vo at an angle of 30 degrees above horizontal. Building B is .9m shorter than building A. What horizontal distance was covered by the stuntman given he makes it to the very edge of building B? What was the maximum height with respect to the starting point attained by the stuntman?
Displacement and velocity kinematic equations.
displacement x= cos(30)*Vo*1s
displacement y= sin(30)*vo+.5(-9.8)(1)-.9m
I know that somehow i need to find Vo from the Y data then plug it into the x displacement equation but i am not sure how this is going to be possible with the given information.
Your equation giving y has an incorrect value for the initial vertical position. The general form is
y(t) = y0 + voyt - (1/2)g t2
What is the value for y0? In other words, if you plug in t=0 in the above equation, what should y0 be so that it matches the vertical position of the stuntman?
oh should it be a +.9 since at t=0 he is .9 above where he will end up?
Yes. So his initial vertical position is 0.9 m and his final vertical position is 0 m. Now you can put the equation together.
  • · Replies 38 ·
