Sliding Friction on a Wheel: How Does Static Friction Prevent Motion?
The discussion centers on the role of static friction in the motion of a sliding wheel. It establishes that static friction acts at the point of contact when the wheel is not slipping, meaning the linear velocity is directly related to the angular velocity and the radius of the wheel. When a wheel has both linear and angular velocity without slipping, static friction is the relevant force, not kinetic friction. This distinction is crucial for understanding how wheels function in motion.
  • Understanding of static and kinetic friction
  • Knowledge of linear and angular velocity
  • Familiarity with the concept of wheel rotation and slippage
  • Basic principles of mechanics and motion
  • Research the coefficients of static and kinetic friction
  • Learn about the relationship between linear and angular velocity in rotating bodies
  • Explore the physics of rolling motion and its applications
  • Study the effects of slippage on frictional forces in wheels
Students of physics, mechanical engineers, and anyone interested in the mechanics of motion and friction in rotating systems.
DZABHINAV
How is a sliding wheel is opposed by static friction?
Static friction acts only when the body is about to move.
My point is
if the wheel is has a linear velocity and angular velocity than kinetic friction should act on the body rather than static friction.
My point is
Look at the point where the wheel contacts the ground. Is the wheel turning without slipping? That is, is the linear velocity just related to the angular velocity and the radius? Or is the wheel sliding on the ground as well as rotating? If there is no slippage, you would use the static friction coefficient.
that means cause the point of contact is motionless, we call it static friction.
thanks a lot.
  • · Replies 27 ·
  • · Replies 59 ·
  • · Replies 22 ·
