Lifting attachment design factors
The discussion focuses on determining the allowable stress for a lifting attachment made from mild steel, specifically a block that connects to a component for crane lifting. The user has applied a dynamic load factor of 1.3 and is evaluating the appropriate factor of safety (FOS) based on standards such as BS2573, BS5950, and BS449. It is concluded that for lifting attachments, a yield factor of safety of 3.0 and an ultimate factor of safety of 5.0 are standard practices, although the applicability of BS2573 to lifting attachments remains uncertain.
  • Understanding of lifting attachment design principles
  • Familiarity with British Standards BS2573, BS5950, and BS449
  • Knowledge of load factors and safety factors in engineering
  • Basic principles of stress analysis in materials
  • Research the specific applications of BS2573 in lifting attachment design
  • Study the differences between yield and ultimate factors of safety
  • Explore material properties of mild steel relevant to lifting applications
  • Investigate best practices for calculating dynamic load factors in lifting scenarios
Engineers, safety professionals, and designers involved in lifting equipment and attachment manufacturing will benefit from this discussion, particularly those focused on compliance with safety standards and stress analysis in lifting applications.
leon25034796
I'm looking for some advice:
I am trying to determine the allowable stress in a lifting attachment we have had manufactured. The lifting attachment is a mild steel block that bolts to the component to be lifted with a lug to enable a shackle to be fitted; two of these blocks are then fitted to the component at either end and the component is then lifted by crane.
When calculating the stresses in the component I have multiplied the load by 1.3 for a dynamic load factor. What I am trying to determine is the allowable stress i.e. FOS required. I have had a scan through BS2573, BS5950, BS449.
BS2573 seems the simplest to follow and I believe BS5950 is a plastic code where I am interested in elastic. However is BS2573 applicable to lifting attachments as it seems predominantly concerned with cranes?
leon25034796: I am not familiar with those cited standards, but I seem to recall that, for lifting attachment hardware, you typically use a yield factor of safety of 3.0, and an ultimate factor of safety of 5.0.
  • · Replies 22 ·
