Principal root of a Complex Number
The discussion focuses on finding the principal root of the complex number (-8 - 8√3i) raised to the power of 1/4. The four roots identified are ±(√3 - i) and ±(1 + √3i). The vertices of these roots form a square in the complex plane, confirming that the fourth roots of a non-zero complex number are positioned at the corners of a square. The principal root is defined as the root with the smallest standardized argument.
  • Understanding of complex numbers and their representation in rectangular coordinates.
  • Familiarity with the concept of roots of complex numbers.
  • Knowledge of principal arguments in complex analysis.
  • Ability to graph complex numbers in the Argand plane.
  • Study the properties of complex number roots, particularly focusing on De Moivre's Theorem.
  • Learn about the Argand plane and how to graph complex numbers effectively.
  • Research the concept of principal arguments and how to calculate them for complex numbers.
  • Explore the geometric interpretation of complex roots and their arrangement in the complex plane.
Students studying complex analysis, mathematicians interested in complex number theory, and educators teaching advanced algebra concepts.
DEMJ
Find all the roots in rectangular coordinates, exhibit them as vertices of certain squares, and point out which is the principal root.
The problem is [tex](-8 -8\sqrt{3}i)^{\frac{1}{4}}[/tex] and I found the four roots easily to be
[tex]\pm(\sqrt{3} - i), \pm(1 + \sqrt{3}i)[/tex]. So when it says to exhibit them as vertices of certain squares does this mean I should just graph the four points? and it should be a square.
Also as for which point is the principal root I have no clue. I am guessing it has something to do with principal argument but I am having trouble finding much information on principal roots.
For any non-zero complex number, its fourth roots are arranged on the vertices of a square. You are being asked to verify this for the given number.
If I'm not mistaken, the principal root is the root whose standardized argument is least.
--Elucidus
  • · Replies 22 ·
  • · Replies 27 ·
  • · Replies 23 ·
  • · Replies 30 ·
