Is the Surface Gravity of Mu Arae-c Miscalculated?
  • Thread starter Thread starter Researcher X
    Gravity Surface
The surface gravity of Mu Arae-c is under scrutiny due to conflicting mass and density estimates. Initial calculations suggest a density of 189.74 kg/m³, which is implausibly low for a solid planet, especially one theorized to have originated from a gas giant. A revised density estimate of 1240 kg/m³ aligns more closely with expectations for a terrestrial planet, yet still raises questions about the planet's mass of 10.5 Earths and its claimed radius of 0.6 Jupiter diameters. The discrepancies indicate that the current hypotheses regarding Mu Arae-c's formation and characteristics may be fundamentally flawed.
  • Understanding of planetary formation theories, particularly gas giants.
  • Familiarity with density calculations and their implications for planetary mass.
  • Knowledge of gravitational concepts and surface gravity calculations.
  • Experience with astronomical measurement units (kg/m³, g/cc).
  • Research the methods used to estimate the mass and radius of exoplanets.
  • Explore the implications of density variations in solid versus gas giant planets.
  • Study the formation processes of terrestrial planets from gas giants.
  • Investigate the gravitational effects of mass and density on surface gravity calculations.
Astronomers, astrophysicists, and planetary scientists interested in exoplanet characteristics and formation theories will benefit from this discussion.
Researcher X
I was wondering about the possible surface g of this giant rocky planet, and I found this one origin hypothesis on wikipedia.
"If an eroded gas giant, the sun would have boiled the planet from a larger protoplanet, of 20 Earth masses up to half Jupiter's mass. If the latter, its current radius could be as high as 0.6 Jupiter."
With this radius/volume estimate, and the mass (10.5 Earths), put into a density calculator, we get a puny and utterly impossible 189.74kg/m^3. If it's the remaining solid core of a gas giant, shouldn't it be incredibly dense? And it simply cannot be this diffuse.
Balsa wood can sometimes be heavier than this. This is 0.034385647 x Earth's density. Even Saturn is about six times denser.
Using this mean density with the estimated maximum radius, I get only 0.2g.
Before I mixed up kg/m for g/cc and got the g to 34.385646974g and with the early 14e mass of the planet, I got the ridiculous figure of 310g.
So, I've got it either way too heavy or way too light. Where have I gone wrong? Or is the radius estimate on wiki waaaaaaay off. I wouldn't expect it to be that large after all.
I've seen 3.5g for this planet before, but I don't know how that was come to.
Astronomy news on Phys.org
Note "if the latter", which means half Jupiter's mass. If we use that as the mass, the density comes out to a reasonable 1240 kg/m^3.
I see, but that is odd because it was already penned at 14 Earth masses, and then revised to 10.5. When it says "20 Earth masses to 1/2 Jupiter's mass". it means that it eroded from that mass of a gas giant down to the current terrestrial planet mass of 10.5.
1240 kg/m^2 would make more sense though. Even still, not entirely, because that would make it less dense than Earth, and we're not talking about a gas giant, we're talking about a solid planet that may have eroded from a gas giant. It's current density should be a lot greater, which is why I also can't console 0.6 Jupiter diameters (the claim for its current diameter) with 10.5 Earth masses (the current mass estimate). It just doesn't add up, and gives it an impossibly low density for a solid planet of that size. If it was 0.6 Jupiter diameters it would be much more massive than 10 times the Earth. Does this mean that that hypothesis is completely wrong?
  • · Replies 22 ·
  • · Replies 24 ·
17K
9K
