How Do You Calculate the Average Acceleration of a Tennis Ball from a Drop Test?
  • Thread starter Thread starter demonelite123
    Ball Tennis
The discussion revolves around calculating the average acceleration of a tennis ball during a drop test, where the ball is dropped from a height of 4.00m and rebounds to a height of 2.00m. Participants are exploring the physics concepts related to motion, specifically focusing on acceleration, velocity, and the effects of gravity.
  • Participants are attempting to use kinematic equations to find the velocity of the ball just before it hits the ground and after it rebounds. There are discussions about the direction of velocities and how to calculate average acceleration based on changes in velocity over time.
Several participants have provided different methods to calculate the velocities involved in the drop and rebound of the tennis ball. There is an ongoing exploration of the discrepancies between calculated values and those found in the textbook, with some participants questioning the assumptions made regarding direction and the application of formulas.
Participants are working under the constraints of a homework problem, which may limit the information available for discussion. There is a focus on ensuring that the directions of velocities are appropriately considered in calculations.
demonelite123
To test the quality of a tennis ball, you drop it onto the floor from a height of 4.00m. It rebounds to a height of 2.00m. If the ball is in contact with the floor for 12.0ms,
a) what is the magnitude of its average acceleration during that contact
and
b) is the average acceleration up or down?
i used the equation x-x0 = v0t + 1/2 at^2. to find the time when the tennis ball just touches the ground, i did 4 = 4.9t^2, assuming down in positive and up is negative. so t = .904. then i used the equation v = v0 + at to find the velocity when the ball just touches the ground. i did v = (9.8)(.904) = 8.85m/s. the ball was in contact with the floor for 12.0ms so the final time is .904 + .012 = .916. so i have my final and initial times and i get .012ms when i subtract them. the only thing I'm missing to find the average acceleration is the final velocity. i tried using v = v0 +at again, v = 8.85 + (9.8)(.916) = 17.826m/s. so i get that the average acceleration is 748.06 upwards. but the answer in my book says 1260. how did they get that answer?
Using the formula
v1^2 = vo^2 + 2g*h, find the velocity with which the ball hits the floor.
Similarly to reach a height of 2 m, what should be the initial velocity after rebound? The velocity of rebound cannot be greater than the velocity with which ball hits the floor.
It the first one is v1 and the other one is v2, then the average acceleration is ratio of change in velocity to the time. While finding the change in velocity, note down the directions of the velocities.
rl.bhat said:
Using the formula
ok so for the velocity the ball hits the ground, i get v^2 = (2)(-9.8)(-4) assuming that up is positive and down is negative so v when the ball hits the ground is 8.86m/s. now to find the initial velocity when its rebounds, i did 0 = v0^2 + (2)(-9.8)(2) because when the ball reaches 2m, that is the maximum height of that path to the velocity at 2m = 0. so i solved and i got the initial velocity when it rebounds is 6.26m/s. however when i subtract the 2 and divide by .012 seconds, i get only 216m/s^2 as opposed to what the book got which was 1260m/s^2. how is the acceleration that big?
8.86 m/s and 6.26 m/s are in the opposite direction. So the change in the velocity is
vf - (-vi)
  • · Replies 17 ·
13K
