If i stand still , you cant find me
  • Context: Graduate
  • Thread starter Thread starter noianiz
The discussion revolves around the interpretation of a statement related to quantum physics, specifically addressing the uncertainty principle and the wave-particle duality of matter. Participants explore the implications of these concepts on the ability to determine the position and momentum of particles, as well as the nature of particles as waves.
  • Some participants suggest that the statement reflects the quantum mechanical principle that position and momentum cannot be simultaneously determined, leading to inherent uncertainties.
  • One participant explains that measuring momentum requires high-frequency radiation, which can disturb the particle's position, thus increasing uncertainty in momentum when position is more accurately measured.
  • Another participant emphasizes that uncertainty is a fundamental property of quantum systems, not merely a consequence of measurement techniques.
  • A historical perspective is introduced, referencing Louis de Broglie's hypothesis that particles exhibit wave-like behavior, which challenges traditional notions of position and momentum.
  • Participants use analogies involving waves and pulses to illustrate the trade-off between knowing a wave's position and its speed, reinforcing the idea that one cannot have precise knowledge of both simultaneously.
Participants generally agree on the existence of uncertainty in quantum mechanics and the wave-particle duality, but there are differing interpretations regarding the nature of this uncertainty and its implications for measurement. The discussion remains unresolved regarding the deeper implications of these concepts.
Some limitations include the dependence on definitions of position and momentum, as well as the nuances of wave-particle duality that may not be fully addressed in the discussion.
noianiz
is someone so kind to explain the statement : quantum physics says : if i stand still you can't find me.
i guess it have something to do with the " you can only know where its going and how fast" atom thingy..
as you can hear, I am not into physics, I am just really really interested in it.
Thanks in advance!
Noiatypo
I guess you refer to the quantummechanical fact that momentum and position can't be determined at the same time. So the narrower you pinpoint the position of a particle, the more uncertainty you get where this particle is going to (momentum tells you where and how a particle is heading).
Intuitively, you can understand this as follows: measuring the momentum of a particle requires radiation with a very small wavelength. Because, a small wavelength means a high frequency, which means a lot of waves in a certain time interval, and the more waves you have in a certain time interval the better you can detect changes in this wave due to the momentum of the particle you want to measure. But, the smaller the wavelength of the radiation, the more energetic the radiation becomes, and the more it will kick the particle of its position.
So you decide to lower the frequency of the radiation in order to determine the position better, but then the uncertainty in the momentum becomes bigger again.
The problem with this explanation is that it appears to suggest that uncertainty is merely a measurement problem. It is not. Uncertainty really is a property of the system, not just the measurement technique.
"If I stand still, you can't find me"
In 1924 a physicist named Louis de Broglie suggested that since light was made up of photons (waves made up of particles), then perhaps particles were also wave-like in nature. People thought he was crazy at first, but experiments suggested that this was true: particles are waves.
Now transfer your thoughts to a situation involving a rope tied to a wall. If you were to jerk the rope once, it would send a pulse across the length of the rope. You could see that single pulse and roughly describe where it is. It has a well defined position.
Now let's say you jerk the rope several times to create a series of pulses, i.e. a wave. You could easily measure the frequency and wavelength of this wave you created (the frequency is the number of times your jerked the rope per second, the wavelength is the length between the top of two pulses.) If you multiply the wavelength and the frequency, you get the velocity of the wave. You can say this wave has a well defined speed.
Now look at the first situation, the single pulse. You can say you know just about where that pulse is located, but you only have one pulse, so you don't know the wavelength (distance between two pulses). You can't quite describe the speed of this wave.
In the second situation, you can tell someone that the waves are moving with some speed, determined by the wavelength and frequency. But what if you were asked where the wave was? The wave consists of a bunch of pulses, so it seems to be everywhere at once. This wave does not have a well defined position.
What I'm trying to say is that for waves, you must give up some information in order to get an accurate measurement of some other aspect of the wave. You can either know the (approximate) position of the wave, or you can know the (approximate) speed of the wave, never both.
Back to de Broglie's discovery: all particles are waves, this means electrons, protons, and neutrons (which make up sand, people, elephants, planets, etc) are waves. Now if you are a wave, and you are standing still, why can't I find you?
  • · Replies 20 ·
  • · Replies 65 ·
  • · Replies 26 ·
  • · Replies 38 ·
