How to Efficiently Read and Store Numbers from a File in C++?
  • Thread starter Thread starter cellec
    Argument
The discussion revolves around efficiently reading and storing numbers from a file in C++, as well as the challenges of using runtime values as template arguments. It includes technical explanations and clarifications regarding file input operations and template programming.
  • Fiona's twin__001 questions why the code reads past the end of the file, leading to an extra element in the array, and seeks a solution to limit the read to only two numbers.
  • Warren explains that the stream does not recognize the end of the file until an attempt to read past it is made, suggesting a loop that checks for eof after each read.
  • Fiona's twin__001 asks for further clarification on the second question regarding parsing runtime values as template arguments, indicating issues with the VC++ 6.0 compiler.
  • faust9 suggests that the problem may stem from trying to use runtime values in a context that requires compile-time constants, recommending dynamic memory allocation as a potential solution.
  • Another participant, faust9, provides links for further reading on dynamic memory in C++.
  • Fiona's twin__001 clarifies that their issue is not about memory allocation but rather about using user input as a template argument in a class.
  • A participant states that template parameters must be constants and that there is no way to use runtime values as compile-time constants.
  • There is a light-hearted exchange regarding the term "Big catch-22," with some humor added to the discussion.
Participants express differing views on the nature of the problem, with some focusing on file reading mechanics and others on the constraints of template programming. The discussion remains unresolved regarding the best approach to handle runtime values in templates.
There are limitations regarding the assumptions made about the code's behavior and the specific requirements of the compiler being used. The discussion does not resolve the technical challenges presented.
Readers interested in C++ programming, particularly in file I/O operations and template programming, may find this discussion relevant.
cellec
Two questions,
1) Can you tell me why
PHP:
ifstream f("f.txt"); //there are 2 numbers in file f
int count=0
while(!f.eof()){
f>>x[count];
count++;
Why does there exist to be x[2] ? How can I chaneg the code to get only two x[0],x[1];
2) Completely different though,
Are there any ways to "parse" the values i.e integers as the template arguments at runtime ? My VC++ 6.0 compiler complains that i can't pass the numbers directly like that at run time.
Thanks in advance,
-Fiona's twin__001
Computer science news on Phys.org
Because the stream doesn't recognize eof until after you've actually attempted to read past the end of the file. A better solution would be
Code:
while(1) {
f >> x[count];
if (f.eof()) break;
count++;
- Warren
Thanks chroot, -->lol
Anyone has any ideas about my second question ?
Well, with the limited info you provided I'd say your problem is you're trying to compile a program which relies on runtime values but the program requires those values before it can compile. Big catch-22 huh? Do a google search for "new C++ dynamic memory" and you'll find the answer. Here, a couple of links from said same search to get you started if I'm reading your problem correctly.
http://www.jive.nl/~kamphuis/eff_c/dmemory.html
http://cplus.about.com/library/weekly/aa072502b.htm
http://www.cplusplus.com/doc/tutorial/tut3-4.html
Basically, you need to create a pointer of the desired data type then use the new operator so your compiler knows you want to use runtime variables.
Hope this helped, good luck.
faust9, I would like to make some questions,
1) What is Big-catch 22 ?
2) Thank faust9 very much for those links, but my problem I think is not about memory allocation...My program asks the user to input a number and it will output numbers circling with radius 5, around the input, all are of course integers. But I tried using template in my program and I would like to put that input number in something like Circle<num> which is where compiler give me lots of complaints...Do you know how I can do something like std::count<<Circle<Num> ?
Template parameters must be constants; there is simply no way around this. While there are lots of clever ways to compute constants at compile-time, the fact remains that they are still constants; there is absolutely no way to grab a runtime value and turn it into a compile-time constant.
Big catch 22 might mean using 22 to have a big catch /--lol--\
  • · Replies 23 ·
9K
  • · Replies 16 ·
15K
35K
  • · Replies 24 ·
