What Frequency Do You Hear from a Speeding Train's Whistle?
  • Thread starter Thread starter Dx
    Sound Sources
The frequency of a train whistle heard by an observer when the train is traveling at 120 km/h is calculated using the Doppler effect formula: f' = f / (1 - vs / vo). In this case, the original frequency (f) is 400 Hz, the speed of the source (vs) is 33.33 m/s (converted from 120 km/h), and the speed of sound (vo) is 340 m/s. The correct frequency heard is 364 Hz, confirming that the initial calculations were incorrect due to a misconversion of speed units.
  • Understanding of the Doppler effect
  • Knowledge of speed conversion from km/h to m/s
  • Familiarity with basic physics formulas
  • Ability to perform algebraic calculations
  • Study the Doppler effect in detail, focusing on moving source and observer scenarios
  • Practice converting speeds between km/h and m/s for accurate calculations
  • Explore examples of sound frequency changes in various contexts, such as emergency vehicle sirens
  • Learn about the implications of sound speed in different mediums
Students in physics, educators teaching sound waves, and anyone interested in understanding the principles of sound frequency changes due to motion.
Dx
A train is traveling toward you at 120km/h. The train blows its 400Hz whistle. take the speed of sound to be 340m/s. what's the frequency do you hear?
f'=f/(1-vs/vo)
400/(1-(4.32x10^8 / 340)) i got 4.32x10^8 = 120000m * 3600sec
what am i doing wrong?
The possible answers are: which is it and what have i done wrong to miss this test question?
a) 444hz
b) 364hz
c) 361 hz
thanks!
Dx :wink:
Originally posted by Dx
f'=f/(1-vs/vo)
You made a mistake converting the speed of the source from km/h to m/s. If you look at it, you have the source moving faster than light, which is a big no-no.
Based on the given information, the correct answer is b) 364hz. To arrive at this answer, you have to use the formula for frequency of a moving source, which is f'=f/(1-vs/vo). In this case, f is the original frequency of the whistle, which is 400Hz. vs is the speed of the source, which is the train moving at 120km/h or 33.33 m/s. vo is the speed of sound, which is given as 340m/s. So, the equation becomes f' = 400/(1-33.33/340) = 364hz. Therefore, the frequency you hear is 364hz. You may have made a mistake in your calculations, which is why you got a different answer. Make sure to double check your numbers and use the correct formula to arrive at the correct answer.
13K
