Force Between Carts: Homework Statement & Solution
  • Thread starter Thread starter Anirak
    Carts Force
The problem involves analyzing the forces experienced by two carts in four different scenarios, including collisions and interactions where one cart pushes or pulls another. The subject area pertains to Newtonian mechanics, specifically focusing on forces and interactions between objects.
  • Participants discuss the forces exerted by the carts on each other, referencing Newton's third law. Some question the original poster's assumptions about the forces felt by each cart in different scenarios.
There is an ongoing exploration of the forces involved in each scenario, with some participants clarifying that the forces exerted by the carts on each other are equal. The discussion reflects a mix of interpretations and attempts to align understanding with the principles of physics.
Participants note the importance of distinguishing between the forces exerted by the carts on each other and the total forces felt by each cart. The original poster expresses a desire to understand the reasoning behind any corrections, indicating a focus on learning rather than just obtaining answers.
Anirak
The problem is to give the forces that two carts experience in 4 different situations. A java applet was provided to simulate the situations which is http://physics.bu.edu/ulab/prelabs/prelab_forces_1.html" , but I will describe them as well, just in case you don't have java or don't want to load the applet.
1) Two carts of equal mass colliding. The first of the carts is in motion toward the second, which is stationary. Upon collision, the first cart stops moving and the second begins moving.
2) Two carts of unequal mass colliding. A cart with a mass of 1 unit is moving toward a stationary cart with a mass of 3 units. Upon collision, they both move in opposite directions with respect to each other.
3) One cart of mass 1 unit is pushing a cart with mass of 3 units.
4) One cart is pulling another cart of equal mass using a rope.
I suppose F = ma
1) Since they are of equal mass I am assuming equal force felt by both carts upon collision.
2) Since the bigger cart has more mass, it should exert more force, therefore the smaller cart should feel more force.
3) The lighter cart should be feeling more force since the heavier massed cart has a greater force.
4) The forces should be equally felt since both carts are feeling the tension from the rope attached to an equal-massed cart.
Thanks for any help you could give me, and I'd like to know the reasoning behind any corrections you have if it's not too much trouble (since I'd like to learn the stuff rather than just get answers).
In all four cases, the first cart exerts the same force on the second as the second does on the first. This is a direct restatement of Newton's third law. I doubt this was supposed to be your answer, however; what did the question say, word-for-for?
This is literally the exact page: http://physics.bu.edu/ulab/prelabs/prelab_forces.html
But I will go ahead and quote the questions:
For each case predict which cart experiences a larger-magnitude force by circling one of the choices below.
Case 1: cart 1 feels more force cart 2 feels more force forces are equal
Case 2: cart 1 feels more force cart 2 feels more force forces are equal
Case 3: cart 1 feels more force cart 2 feels more force forces are equal
Case 4: cart 1 feels more force cart 2 feels more force forces are equal
Did you check out the simulation link I posted? I'm sure reading about it in text just doesn't have the same effect: http://physics.bu.edu/ulab/prelabs/prelab_forces_1.html
Ah, so the lab is indeed talking about the forces exerted by the carts on each other, not the total force felt by each cart. In that case, forces are equal in all four simulations. It's a property of the universe that whenever two objects interact, they must exert the same force on each other but in opposite directions. That's known as Newton's third law.
(By the way, I did check out the simulation, but it doesn't change my answer.)
Alright, thanks man, I appreciate it!
  • · Replies 32 ·
  • · Replies 40 ·
  • · Replies 24 ·
  • · Replies 16 ·
  • · Replies 47 ·
