The discussion revolves around the implications of Galilean transformations on the postulates of light, particularly whether these transformations violate the constancy of the speed of light as stated in special relativity. Participants explore the addition of velocities in different frames of reference, using both classical and relativistic perspectives.
Debate/contested
Technical explanation
Mathematical reasoning
Some participants argue that using Galilean transformations leads to contradictions regarding the speed of light, particularly when adding velocities such as c + 3/4c = 7c/4.
Others propose that the relative velocity of a moving frame and a photon can be calculated as c - 3/4c = c/4, suggesting no violation of light postulates occurs.
One participant emphasizes that the speed of light remains invariant and that any addition of velocities should not change this invariant speed.
Another participant introduces the relativistic velocity addition formula, w = (u + v) / (1 + uv/c²), asserting it preserves the constancy of the speed of light.
Some participants express skepticism about the interpretations of velocity addition and the implications for the understanding of light speed, suggesting that common assumptions may have led to misunderstandings in physics.
There are claims that previous calculations were based on stationary observers, which may have contributed to the belief in the invariance of light speed.
Participants do not reach a consensus; multiple competing views remain regarding the implications of Galilean transformations on the postulates of light. Some assert that no violation occurs, while others maintain that the invariance of light speed is compromised.
There are unresolved assumptions regarding the definitions of velocity in different frames and the implications of using classical versus relativistic approaches. The discussion reflects a range of interpretations of how velocity addition should be approached in the context of light.
#1
geistkiesel
538
Doc Al said:
"... caught on to Galilean relativity ..."
I just finished the first page of the URL at the motivation of my personal mentor, Doc Al.
The writer showed examples of adding velocities using non photon entities. In using the photon in order to show that postulates of the speed of light would be violated if the observer shines a light ahead of his frame moving at 3/4c and adding velocities as,
c + 3/4c = 7c/4
This surely would a bring a contradicition of the postulates of the constancy of the speed of light limited to a maximum of 4c/4.. But wait a minute. If A is moving to the right and B is moving to the left what is their relative velocity? It is,
v(A + B) = V(A) + v(B),
and yes, the velocities are added to determine their relative velocity, which is greater than either velocity alone. But the writer in our example says the light was shined ahead of the moving frame moving in the direction of the light flash. To find the realtive velocity of the frame and photon entities using a standard Galilean transformation we write the relative velocity as a subtraction, or as,
c - 3c/4 = c/4.
So we have no contradiction of a postulate of light regarding maximum speed allowed do we, or even of measurement of the speed of light? And boy it sure seems rational that the relative velocity of the photon and frame is their difference. Do you think the writer was trying to fool us?
I made a mistake above. The c + 3c/4 = 7c/4 doesnot vioate any postulate of lihjt. What we arediscussing here is the realtive velocity of frame and photons. An expanding velocity of 7c/4 is reasonable and rational.
Hey Doc Al, this Galilean stuff is great, thanks for turning me on. Now I can really begin to live!
c + 3/4c = 7c/4
c - 3c/4 = c/4.
Yes it does violate the postulate of light velocity because the postulate states that the speed of light is invarient. For the speed of light to be invarient the answer you get when you add c to any velocity will must be c. (not 7c/4 or even c/4)
The formula that perserves this, and is the correct formula for the addition of any velocities is
[tex]w = \frac{u+v}{1+\frac{uv}{c^{2}}}[/tex]
#3
geistkiesel
538
You missed the point. The velocity of light did not change. Nothing changed. We made a simple addition of velocities and did not vary c. When you add the observers velocity you don't change c you determine the relative velocity., simple isn't it?
We subtracted the observers velocity from C to get c/4 a reasonable relative velocity under the conditions given. Remember the link. The writer there stated the velocity of the observer and the light was c + v, when the true or correct addition is c - v. Similarly when the observer and light are moving in opposite directions the velocity is added, v(a + B) = v(A) + v(B). In that case the relative expansion velocity is 3c/4 + 4c/4 = 7c/4. I see no violation.
How do you add velocity? And why do ou do it your way? I opine you are thinking ahead, anticipating long memorized SR theory and aren't keeping track of the steps as you go rushing along. Tres dangereaux, n' cest pas?
Show me where c is not measured as c. Can you do this?
This is only an observation, but I see you giving me a mathematical formula and I give you physics arguments. Not necessarily that one is better than the other, it is just an observation. This is the error I see in this simple first step into Galilean Transformations, where light postulates are not violated.
You see Janus you have a long way to go to arrive at your fornmula, and quite frankly, just repeating formula mantras don't cut it any more around here. You have to prove it. Do you think I don't know of your ideas, or the ideas of SR?? Get real man.
#4
ram1024
301
Geist: i made a discovery in the other thread. It's looking like for every "moving observer" case all the calculations were done as "stationary observer" with "stationary sources" so that's why they believed that light speed was invariant relative to the viewer.
such a simple mistake has set physics and astrosciences back 100 years :D
#5
eJavier
59
So far, all experimental data confirms the postulate that the speed of light must be the same for every inertial observer. And that doesn't follows from your theory.
Edit: rephrased
geistkiesel
538
We see alike. Welcome pilgrim.
#7
ram1024
301
i guess that's why Tom didn't come back with the data...
it's either that or something terrible happened to him and that would suck much, so i take the lesser "evil"
#8
wespe
202
You mean:
"When you add the observers velocity, you don't change c"
"When you add the observers velocity, you determine the relative velocity"
You are still thinking c is speed of light relative to aether or something (so it doesn't change). No, c is the relative speed with respect to every observer. In other words, after the addition/subtraction/calculation we should find c as the relative speed, in order to conform to experiment results. The formula Janus gave finds c, simple addition/subtraction does not.
#9
wespe
202
Please carry out an experiment to measure the speed of light. You can't? OK, somebody else did. They found c. So it is not just calculated/believed, it was measured.
#10
geistkiesel
538
Edit: rephrased
I really don't have a theory. I referenced the link I was studying and I merely looked at the way the writer there handled addition of velocities. Your statement of experimental proof is valuless here unless you are able to discuss the experiments in detail. Can you do this, or are you just echoing SR dogma?
He stated that for an observer moving with velocty 3c/4 in the direction the observer shined his flaslight that Galilean transformation would result in 4c/4 + 3c/4 = 7c/4. I merely observed that he was adding velocities improperly. If automobiles are moving away from each other one adds the relative velocites to get maxim relative speed, right? maximum speed? If the automobiles are moving in the same direction one subtracts the velocities or 4c/4 - 3c/4 = 1c/4, which seemed like a rational and reasonable number, especially after I detected the error. If the observer was moving in the opposite direction from the light we add the velocities or 4c/4 + 3c/4 = 7c/4 which is a righteous expanding velocity form oppositely moving particles.
Some have objected that I a violated a postulate of light, that the speed of light is always measured as c. I was raised in a morally healthy family situation and I tell you that I did not violate, nor did I alter the speed of light one tiny fraction of a m/s, trust me.
This is very important: Measuring relative velocity with a photon and object does not vary the speed of light. The addition of velocities merely determines the relative velocity and the SR theorists must prove the contrary. You don't have to remind me that I am swimming upstream, I know it so, very clearly.
I know that SR theorists are going to complain about this and that, they already have, like yourself, what's your story? How did you fall into the SR trap?. Well let them, this thread is titled "No postulate of light is violated in Galilean Transformation." If people are gping to respond to the thread they should keep on track, don't yopu agree?. Just saying "No No that's not allowed by SR", doesn't cut through any chaff. The SR theorists are still blinded by the simple title as I sneak through their net. I would have used Guile and Cunning but they'e still in jail on some kind of technicality thing, like a mistake, or something like that, like a misunderstanding.
It should be a slam dunk easy as pie task to prove that what is said in this thread, by myself or any else does not conform to physical law.Those that want to trade witticisms, or preach the history if physics, as an offer of proof best have something substantial to say, other wise you will be directed, yes you, to the most brutal of task masters in this forum. Can you take it like a man, or a woman, I mean can you stand up to Doc Al when he really gets wound up and in your face? I can't, I couldn't, I had to surrender, finally.
What you need to do to get the most from this thread is to prove me wrong, or prove yourself right, [I'll take either one, though I do have a preference.] but keep your rote SR mantras to yourself, bitte schön. I don't mean to be mean and blunt, but time is skitting along. I mean it.
I have already been certified as "outre" if you know what I mean, so unless you have a uniquely interesting tag to place on me as a physical argument please be creative, OK? As the song goes, "I've got skin like iron and breath like kerosene, I wear my gun outside my pants for all the world to see." from "Poncho and Lefty", Willy N, et al.
#11
geistkiesel
538
Educating Wespe: somebody has to do the hard work.
wespe said:
You mean:
wespe, prove it. Just don't bark SR mantras at me OK? Not this time.
Please see where and what I was talking about. Here take a look, below, before you open your doodling fingers. Prove what you have to say. in the context of what is said. This is one step at a time, do you understand?. One step at a time. Intro to Galilean transformations 101..
Do you hionestly think I don't know what SR has to say about velocity addition? Do you honestly believe I didn't anticipate posts such as yours?
read and weep, wespe. http://theory.uwinnipeg.ca/mod_tech/node134.html
ram1024
301
exactly as he says. moving observer has nothing to do with the speed of light because he is not TIED to the light.
Aether does not MOVE at the observer's velocity. there is no Aether... :D
Light will move at "c", Calculated or Measured (if you know what you're doing <wink>)
#13
wespe
202
geistkiesel said:
wespe, prove it.
Prove what? Which one is the exact statement you disagree?
Do you mean prove this statement? Experiments prove this. The speed measured in experiments (c) is relative speed of light with respect to the experiment apparatus, of course. Do you disagree?
I'm glad to see you are finally learning something about Galilean tranformations! Good for you. Welcome to the wonderful world of frame swapping.
But you are still a century behind if you think Galilean transformations describe how velocities are added in the real world. (Of course they are a wonderful approximation for low speeds.) Using Galilean transformations to talk about light is just plain silly.
If you have secret knowledge of SR... why have you been hiding it so well in all your hundreds of posts? You sneaky devil!
#15
geistkiesel
538
This is the link I am looking at. I am stepping through the pages and taking them as face value. So far all I have seen ar esimple statenments that say this or that. http://theory.uwinnipeg.ca/mod_tech/node133.html
I hyaven't seen anything that insist I do anything that I agree has to be done. Sying it is oart of SR isn't enough. For instance the addition of velocities follows from the statements ergarding the popstiulates of SR that are derived, at least partilly, from simultaneity conisderations.. I don't see the magic in light phenomena that says it is of such a nature that I can't move with respect to it and measure my speed with respect to the light.
The "measurement of he speed of light" being equal in all frames comes partially from the measurement of light speed being c and partially from relativity considerations. Einstein tells us that relativity consideration imposes the restiction that we measure the speed of light the same from whatever frame measured. I just don't happen to see it thay way at this juncture.
other rhan the relativity statement being widely recognized in SR do you see any physical reason that we allow ourselves the addition of velocities when considering stampeding elephants and Ford Futuras, but not stampeding elephants and photons?
Soon we will be discussing the dilation of light. Read ahead in the link and see if the discussion there fits with everything you have learned regarding the propagation of light. There is a glaring contradiction from which the "dilationists" take off in wild abandon. Glaring!
Geitskeissal everything in special relativity logically follows on from the 2 postulates (the invariance of the speed of light and the laws of physics in inertial reference frames) + pre-relativstic classical physics.
The postulates aren't derived from anything else but experiment, the failure of simultaneity at distance needn't be considered to arrive at the formula for the addition of velocities, as both are derived directly from the postulates of special relativity.
#17
wespe
202
You quoted but didn't answer my questions...
I didn't say speed of light is constant because of SR. I said experiments and measurements say so. Look up any experiment that measured the speed of light. All find c [within experimental error]. Plus, MMX. (dont' say Miller, you never answered my post https://www.physicsforums.com/showpost.php?p=248717&postcount=241)
The special thing about light is that it has zero rest mass.
Where did you get this idea? Velocity addition formula Janus gave applies to all velocities. Galilean formula is an appoximation for low speeds only.
geistkiesel
538
Janus is a robot. Hr repeats what somebody told him. He poves nothing. He attempts to prove nothing.
The horizontal lines are mirrors reflecting a light pulse. Each pulse takes one second to go from floor to ceiling, or round trips take two seconds.This is a clock wih an invaiant time cycle.
The two lines ,the right one "down" the left "up", should be supperimposed on each other and shown separate for instructional puposes. It is the frame that moves. Right? Isn't this the law of he propagation of light? Answer:yes.
Using th extended light ray as indicated in this linkis the corruption on the construction of time dilation, all followed so robotically by the masses of SR theorists that want to be.
Next post how to make a light clock that works. Stay tuned.
Responders, if any, please use the laws of physics in your posts.
In arriving at a time dilaion result the physics of light propagation is ignored.
This is so badly mistaken, I can hardly believe that anyone who claims to have studied any physics could say it. Time dilation comes from precisely a very careful consideration of the physics of light propagation. You've demonstrated over and over again that you don't understand how light propagates anyway, so I guess I shouldn't be too surprised at this.
Question: Does the velocity of the source of light get added to the velocity of light?
No, it's your logic that is bogus. The assumption you are tacitly making is that the Galilean velocity addition formula should hold. But it doesn't.
Janus tried that, and you called him "robot". So what's the use?
#20
wespe
202
Geistkiesel,
It turns out how light travels [direction]* is not totally independent from the source if the source is moving perpendicularly (this is something I didn't think clearly before, thanks). But, still, speed of light must remain the same, because otherwise you could send a message faster than light.
Suppose light source is stationary and a message is sent from A to B in 1 second.
Code:
_________B________
_________|_________
A
Now, the light source is moving perpendicularly. According to the stationary observer, light is traveling diagonally, but it must still travel the same distance in 1 second:
Code:
_________________C
_________/________
A A'
distance from A to C is longer, so information can't be sent in 1 second. It should take more time (hence the time dilation)
According to the moving frame, light traveled perpendicularly, but it was C that moved to the old position B, so it still took 1 second:
Code:
_______ <-C________
_________|_________
A'
Of course, when the first case is viewed from the moving frame, all of this is observed the other way, so both frames see each other's clocks running slower.
edit: (*) I have thought of light as a photon particle above. There's also aberration of light which I don't know exactly. Also there's wave/particle duality but we enter Quantum theory there. So I'm not 100% sure about this.
geistkiesel
538
The speed of light is 3x10^8m/s sure enough, but who prevents one from moving with respect to the light beside SR theory? That is what some say that light has zero rest mass. I disagree for one reason alone. Light exhibits charasteristics indicating a complex polarization mechanism that I find difficult to see formed in a "rest mass = 0 fluidity" . There must be something more substantial, more to the question than a simple m = 0. Those that say m = 0 at v = o have they taken alll the QM aspects into consideration? Correctly? To your satisfaction, from your own investigation? Nope, you haven't, have ya? More work wespe, better get busy, times a wasting.
#22
geistkiesel
538
So everyhting follows logiaically from the two postulates. If physical law is invarinat in all inertial frames, where does simultabeity fit into that? The measure of the speed of light is hard coded into theory and by omitting the observers speed the measure of c in all frames is guarnateed as you say but how
By inserting time dilation and mass shrinking, two very big objections to Sr theory from where I sit. Ad guess what I ain't alone. Check out the other threads on the subject here in Theory Developemnt.
The "who" would be nature
What the bloody blazes is "rest mass = 0 fluidity"?
Of course it has been done correctly. The fact that m=0 implies that there is no |J,M>=|1,0> state for the photon. If m is not zero, then there should be three states:
|J,M>={|1,1>,|1,0>,|1,-1>},
but as it is only 2 are observed. The synthesis of SR and QM is QED, and it has been worked out very completely.
It fits into it via the Lorentz transformations, which are derived from the invariance of Maxwell's equations. I posted a detailed explanation of this some time ago. You acknowledged it, but clearly did not read or absorb it beyond a superficial level.
Not so. The measure of a Lorentz-invariant speed is hard coded into the theory. It is Maxwell's equations that tell us that this speed must be c.
We don't "omit" the observer's speed. In the observer's frame, he is at rest.
Time dilation is not inserted, it is derived.
and mass shrinking,
"Mass shrinking" is not part of SR. In fact, the mass of a particle is an invariant, as it is the norm of the 4-momentum.
"From where you sit", eh? Then it's time for all of you to get up and move to a new chair, from which you can see the blackboard better.
#25
ram1024
301
which means the speed of ALL objects in the universe acquire the observer's velocity, LIGHT INCLUDED.
why would light behave differently? and don't say the data says so, because the data does NOT include the addition of observer motion.
#26
geistkiesel
538
Tom Mattson said:
Janus proved that you have no idea of what the postulate of the speed of light says, or what "invariant" means.
Janus proved nothing . He merely quoted gospel and verse.
"I know I am but what are you?"
No I guess you won't be surprised at this.
When light is reflected between two parallel mirrors that are stationary each reflection follows the exct same path, i.e. one line. Of course, there is always side radiation, but you know of what I speak.
When the mirrors move sideways in a direction parallel with the mirrors, the reflected light does not change [position. Remember, the source of the light, like each reflection from the mirror adds no light velocity in the direction of motion of the mirrors. The light, therefore, remains fixed like a perfect z-axis, stationary, absolute zero velocity. A perfect and absolute frame of refer3enhce.The reflections continues up and down. Eventually the mirrors will come to an end and unless some adjustments are made the left side of the apparatus will simply crash into the z-axis light beam.
Measuring side reflections is an arbitrary piece of physics sloth. The mirror system can measure where each returning relfection is located along the mirror surface, therefore the pulses can be cycled to start over on the right hand side of the apparatus, depending on the measured velocity. It is really an engineering problem tom.
The diection of motion of the apparatus wrt to the z-axis can be detemined in a number of ways, one I just mentioned. Another, for the x-axis is with a modified ram1024 buoy.Don't ever try to tell me tom_mattson that I cannot use the z-axis I just created and use it as an absolute reference frame.
Code:
0 | o |
1 |<-------o-----> |
2 |------> o ------>|
3 ------>o<------|
The 0 level is when the photon is emitted from 'o' to the left and right. Reflectors are situated extending as shown. In 1 the left reflector has closed on the left moving photon. The right reflector already extended is now two units to the right instead of one unit as when the photon was emitted. 2 shows the left photon reflected to the right as the right photon has just reached the right reflector. The next cycle has the photons arriving simultaneously at o where, as Yogi Berra said, "It's dejavu all over again."
As long as the reflection cycle is sufficiently high detector counting arrivals at the various reflectors can maintain a count and hence keep a, solid track of velocity of the appaatus with respect to the absolute point in space designated as the source of the photons. Neat huh? Basic optical engineering 101.
Notice, that inspite of claims
SR,
Galilean transformations,
Lorentzian transformations,
simultaneity,
time dilation
c measured as c in all inertial frames (with time dilation of course)
and length contraction
It all works as designed.
You SR theorists have clouded your brilliant minds with theoretical molasses. Just think where we would all be if the simplicity of physics had been working for the past hundred years instead of that SR crap.
It doesn't work you say? Prove it.
I mean prove it.
Don't send the robot Janus over here with his mantras, or you tom. Show it won't work in an experiment. This is all that will convince me. You are wasting your breath and good finger muscle by attempting to convince me otherwise. I read your galilean post tom and in fact I was impressed which I believe I mentioned. The only thing is it doesn't get us there from here.Those watching may be impressed by your singular and collective brilliances, but I need an experiment. The one shown here is simple enough isn't it? Do this one. Our mutual uncle can afford it. Dig into his pockets.
I understand very well that a good physicist is necessaily a good proposal writer, right?
The physics is extremely simple. The speed of light is independent of the motion of the source. Therefore the the moving apparatus can and does keep a running track of the velocity of the light with respect to the inertial frame. Heresey? Get used to it.
I did learn something I didn't know earlier. That simultaneity is not operational at distances. What distances? What needed adjustment that you discarded or diosconrived your precious simultaneity? It certainly wasn't at the generosity of SR theorists was it? Does that mean we get absolute time back? Wow, just think of it! Or is that only at distance also?
It will hold fpor me. I asked mr. galilean, very politely, if you can believe that!
I think it's funny that you deman experiments to prove SR, but you have none to back yourself.
#28
geistkiesel
538
what is this?
Tom, somethiong completely different. You are the math guru so you figure it out. I found the following in a website' But before that I had developed an expression from an analysis of the Einstein train gedunken. The train moving right detects the B photon coming from the front then the A photon from the rear. Using t1 as the time the B photon was detected measured from the instant the O' observer was at the midpoint of A and B sources in the stationary frame (t2 the time the photons arrived simultabeously at the midpoint of A and B in the stationary frame) and t3 the time of detection of the A photon by O' in the moviong frame as t3, I derived an expression that
t0 the time the O' obsever was at M and the time the photons emitted at A and B. t1 the time B was detected by the moving O'. t2 the time the A and B photons arrived simultaneously at M from A and B. and t3 he time the A photon detected by O'.
From symmetry considerations A and B are equidistant = t1v from M when B is detected. The frame is moving at velocity v. t1 measured from t0 = 0. Therefore the A photon to be detected at t3 it must travel
c(t3-t1) = 2vt1 + v(t3 - t1)
ct3 - ct1 = 2vt1 = Vt3 - V t1
t3(C - v) = t1(C + v)
t3 = t1(C + v)/ (C - v).
Look at the below which I got from the link http://www.mathpages.com/rr/s4-08/4-08.htm
So you the dude with all the math geewhizz, so gee whizz me with the derived expression and the below which comes from the loss of simultaneity with distance. por favor, bitte schön, please.
I f I do it igt would take much miore time than you. Dod Al knows about, but what can I say, Doc and Al and me, well oil and water, as they say.
Letting C = dS/dT denote the speed of light with respect to these rotating non-inertial coordinates, we therefore have C = 1 ± v, where again the sign depends on the direction of the light relative to the direction of rotation of the disk.
Does this analysis lead to some kind of paradox? It indicates that the non-inertial "speed of light" with respect to these rotating coordinates is not equal to 1, and in fact the ratio of the speeds in the two directions is (1+v)/(1-v), but of course this doesn't conflict with special relativity, because these are not inertial coordinates (due to their rotation). However, suppose we increase Rd and decrease w in proportion so that the rim speed v remains constant. The above formulas still apply for arbitrarily large Rd and small angular speed w, and yet the speed ratio remains the same, (1+v)/(1-v). Does this conflict with special relativity in the limit as the radius goes to infinity and the angular speed of the rim goes to zero? Clearly not, since we saw in Section 2.7 that if t1 and t2 denote the travel times for light pulses circling the disk in opposite directions, as measured by a clock at a fixed point on the rim, so that t2/t1 = (1+v)/(1-v), then we have t2/t1 - 1 = f /p, where f is the angular travel of the disk during the transit of light. In other words, the observed ratio of travel times around the rim always differs from 1 by an amount proportional to the angular travel of the disk during the transit of light. Thus the net acceleration (change of velocity) of the rim observer during the measurement remains in constant proportion to the measured anisotropy of the transit times.
#29
ram1024
301
wespe said:
That didn't make any sense when I first read it, but I think I figured out what you mean.
Suppose you are in a spaceship, and some stars ahead look stationary. Then you fire your thrusters for 10 seconds and then you are inertial again. Now you feel you are at rest, but it seems the stars acquired a speed towards you. You meant this, right? OK, but how much speed? Say v. Then you fire the thrusters again for 10 seconds. Now stars seem to have gained some more speed. But how much speed, the same v? No. You repeat this until relative speed of stars is 0.9999...c, then you can't make relative speed exceed c no matter how long you fire your thrusters. Now think that light's relative speed was already c to begin with... And how does this look from an outside observer? Separation speed does look more than c, but that's not what you see in your spaceship. SR effects explain this. See post#2 for the speed addition formula.
you've ALMOST "got" it, wespe. Except that for "the laws of physics" to be the same for "all inertial bodies", a relative speed of 0.9999...c = the rocket stationary and the star moving towards me at 0.9999...c. I can still accelerate just fine thankyouverymuch :D
the reason Einstein has trouble with "speeds never exceeding lightspeed" is from a stationary observer standpoint with his "lightspeed never changes for the observer" postulate that means that objects can only come in towards an observer at light speed or go away from the observer at that speed.
but why suppose the observer is stationary in the first place? if he IS stationary then he has NO problem continuing to accelerate even at a relative separation of 0.9999...c.
let's not even talk about light and assume two spaceships are traveling towards each other at 0.9999...c. if we take one as stationary, the other must be covering the relative distance twice as fast 1.998...c or whatever. F=MA doesn't include am object's current velocity, indeed it doesn't matter because according to the "laws of physics" postulate same force, same mass, same acceleration, no matter the speed.
#30
wespe
202
If you mean a third frame measures each spaceship's speed as 0.9999..c, ok,
yes, if you mean as seen in the third frame. Not so as seen from the spaceships! It's still below c. See again #2 for the formula.
Well, the relativistic mass does increase with speed according to a third frame.
[You know that in particle accelerators, they can't accelerate particles to or beyond c, because mass does increase with speed]
