Max Volume of Cube from 1000 cm^2 Sheet
  • Context: Undergrad
  • Thread starter Thread starter physicsnewb7
    Cube Max Volume
The discussion revolves around the problem of maximizing the volume of a cube or box that can be constructed from a 1000 cm² sheet of material, specifically focusing on the constraints and specifications of the problem, including the shape and thickness of the material. Participants explore various interpretations and mathematical approaches to the problem.
  • Some participants propose that the maximum volume of a cube with a surface area of 1000 cm² can be calculated, with one suggesting a volume of approximately 2828.43 cm³ based on a specific configuration.
  • Others argue that the problem allows for a rectangular prism interpretation, leading to a different volume calculation of approximately 3042.9 cm³ by maximizing the dimensions under the given constraints.
  • A participant humorously claims the ability to create a cube with a volume of 1,000,000,000 cm³ by assuming a thickness of 1000 cm, highlighting the ambiguity in the problem's specifications.
  • Several participants note that the original problem is poorly specified, particularly regarding the shape and thickness of the material, leading to different interpretations of what constitutes a "cube" or "box."
  • Some participants express confusion over the terms used, suggesting that the OP may have meant "rectangular prism" rather than strictly a cube, which requires equal dimensions.
  • Clarifications are made regarding the assumptions about the material being infinitely thin and malleable, which affects the feasibility of constructing the proposed shapes.
Participants generally agree that the problem lacks clarity and that multiple interpretations exist regarding the dimensions and shape of the material. There is no consensus on the maximum volume achievable, as different approaches yield varying results.
Limitations include the unspecified shape and thickness of the material, which affects the calculations and assumptions made by participants. The ambiguity in the terms "cube" and "box" also contributes to differing interpretations of the problem.
This discussion may be of interest to those exploring optimization problems in geometry, particularly in the context of material constraints and design specifications.
physicsnewb7
A sheet of material 1000 cm^2 is given to you to construct a box/cube with no lid. What is the maximum volume of the cube that can be created in cm^3?
Mathematics news on Phys.org
Is the answer something other than the obvious one?
I am going to specify that the sheet is 1mm wide and 100m long.
This allows me to construct the cube from ribbons without wasting any material, meaning my cube will be five panels covering an area of 1000cm^2, so 200cm^2 each, so 14.14cm on a side - for a volume of 2828.43cm^3.
Anyone beat me?
DaveC426913 said:
Anyone beat me?
Sure can.
I'm going to assume that "box/cube" means "box" (rectangular prism) or "cube" so I'll maximize v = x y z subject to xy + 2xz + 2yz = 1000.
This can be greatly simplified by noting the symmetry with respect to x and y (the dimensions of the base) and hence assume that the optimum solution will have x=y.
Maximize v=x^2 z subject to x^2 + 4xz = 1000.
Rearranging the constraint and substituting into "v" gives :
[tex]v = 250 x - 0.25 x^3[/tex]
Maximizing in the usual manner gives x = y = 18.257 cm and z=x/2 = 9.129cm (both approx to 3dp) .
BTW. This results in an aprox volume of V = 3042.9 cm^3.
uart said:
Sure can.
While this is great and everything:
- Is it a cube? It looks to me like it's a prism 18cm on a side and only 9cm deep.
- what does your layout look like on the 1000cm^2 sheet?
- Can you actually build it from the sheet?
My answer should be the largest possible volume (i.e. it should at least equal, if not better, yours). If it isn't, then it's me who's made the mistake in my calcs. See, the only thing I needed to solve was how to maximize the amount of material used from the original sheet i.e. no wastage.
So, let me check my numbers: What is the largest possible cube whose 5 of 6 sides total 1000cm^2? Shouldn't it be only 200cm^2 per face? Which means each face can only be sqrt(200)cm on a side (14.14). How how you get bigger faces?
I have a better answer:
I can make a cube with a volume of 1,000,000,000cm^3, or 1,000m^3.
The other thing not specified in the OP is the thickness of the material. I have chosen a material that is 1000cm thick, meaning I can make a cube from it that is 1000cm on a side.
:approve:
Yes as per usual (for most new users here) it's an incredibly poorly specified problem. The shape of the "sheet" of material was completely unspecified so just make it whatever shape you require for the net of your solution.
As for the box/cube part I genuinely believe that the he meant "box" and the cube part was optional. That is, I think that this was actually meant to be just your typical volume/SA maximization problem (as per my solution).
He specified cube twice.
You stated your assumptions in your solution, granted, but you've redefined "cube":
i.e. box/cube = box = rectangular prism = cube. You have ignored the fact that the rectangular prism's height must equal its length/width to be able to call it a cube.
Yes that's true I cheated in order to make it a mathematically more interesting problem. :biggrin:
Though I'm honestly still tending to think that the OP was erroneously using the term "cube" when he actually meant "rectangular prism" (yes I understand that they're not the same thing).
Yes, being a new user here I lacked certain specifications that would indeed clarify the problem. When I said "material" I meant it to be infinitely thin, like a plane. And the material is perfectly malleable. And when I refer to "box/cube", I mean it must have all equal faces or sides. I didn't want to use just the word cube because it isn't really a cube since there is no top. Thats why I stated a hybrid between box and cube. I apologize for the confusion and appreciate the responses:smile:
That's ok physicsnewb7.:smile:
It just means that mathematically it's not really a very interesting problem, if it must be a cube, since the solution is a little too obvious : [itex]\sqrt{(200)}[/itex] cm per side.
Or was the problem to find a solution whos net could be cut neatly from a rectangular sheet of material (that is,without introducing any extra seams). Can you please elaborate on this?
Yes, I think there's still some ambiguity as to constraints. For example, The xy dimensions of the material are unspecified, so my first answer assumes a extremely thin ribbon, allowing me complete freedom and no waste. Secondly, there's the questions of how one may cut up the material to form the sides.
  • · Replies 16 ·
  • · Replies 16 ·
13K
