Why Do Two Methods Yield Different Results for Charging a Sphere?
The discussion revolves around the calculation of the energy required to charge a sphere with a uniform charge density. Participants explore two different methods for calculating this energy: one using the electric potential and the other using the electric field. The conversation includes attempts to reconcile the differing results obtained from these methods.
  • Claudio presents a problem involving the calculation of energy for charging a sphere using two formulas, which yield different results.
  • Some participants suggest that the discrepancy may arise from the integration constant of the electric potential.
  • Another participant provides a derivation of the potential inside the sphere, indicating that it behaves like a point charge.
  • There is a discussion about the correct expression for the potential V(r) and its implications for the energy calculation.
  • One participant points out that the energy calculated using the electric field method appears to be double that obtained from the potential method.
  • Claudio expresses uncertainty about the calculation of the potential and seeks clarification on the correct approach.
  • A later reply corrects the expression for V(r) and suggests that including the factor of 1/2 in the integral over the potential may resolve the issue.
Participants do not reach a consensus on the correct method for calculating the energy, as differing interpretations and calculations lead to varying results. Some participants agree on the need to clarify the potential used in the calculations, while others maintain that the two methods yield fundamentally different outcomes.
There are unresolved questions regarding the assumptions made in the integration of the potential and electric field, as well as the dependence on the definitions of V(r) and E(x). The discussion highlights the complexity of the problem and the need for careful consideration of the mathematical steps involved.
p3rry
Hi everybody...
this is my first topic here.
I'm solving problems for the phd test here in my university. Here's my question:
I have to calculate the energy of charging a sphere (radius = R) with a uniform charge density "rho".
I can use 2 formulas:
the first is the integral over the space of rho(x)V(x), where V(x) is the electric potential
the second is the integral over the space of epsilon0*|E(x)|^2 where E(x) is the electric field
(there's a 1/2 coefficient for each formula)
If I calculate the 2 integrals I get different results, with the second method I get 2 times the result of the first one. I think it may be explained with the integration constant of V(x), but I'd like to be able to get the same result with this equivalent formulas.
Thank you very much. Bye
Claudio
Thank you very much, there's a straightforward solution of the problem.
But I still have a question. Why if I try to calculate the resultant energy by using equation (587) that's
[tex]W=\frac{1}{2}\int \rho V(r) \mathrm{d}^{3} r[/tex]
I can't get the same energy I get with (594)
[tex]W=\frac{\epsilon_{0}}{2}\int |E|^{2}\mathrm{d}^{3} r[/tex]
I think I'm making a mistake in the calculation of the potential V(r) but I cannot find it out...
Hm, well maybe if you show what you did we can point out where the mistake might be...
First, we calculate the potential for this situation. Inside of the solid sphere, which is the only region that matters for calculating [tex]\int d^{3}x \rho V(x)[/tex], the potential at radius [tex]r[/tex] is the same as that for a point charge with charge [tex]\frac{4}{3} \pi r^3 \rho[/tex]. So, we get
[tex]\int d^{3}x \rho V(x) = \int d^{3}x \rho \left(\frac{1}{4 \pi \epsilon_{0}} \frac{\frac{4}{3} \pi r^3 \rho}{r^2} \right) = \int_{0}^{\infty} dr 4 \pi r^2 \rho \left(\frac{1}{4 \pi \epsilon_{0}} \frac{\frac{4}{3} \pi r^3 \rho}{r^2} \right) = \int dr \frac{4 \pi r^4 \rho^2}{3 \epsilon_{0}} = \frac{4 \pi R^5 \rho^2}{15 \epsilon_{0}}[/tex].
Now we calculate the electric field everywhere. The field is pointed radially outward everywhere. Inside of the sphere, the electric field at a distance [tex]r[/tex] is the same as that of a point charge with charge [tex]\frac{4}{3} \pi r^3 \rho[/tex], so we see that the magnitude of the electric field inside is given by
[tex]E_{\text{inside}} = \frac{1}{4 \pi \epsilon_{0}} \frac{\frac{4}{3} \pi r^3 \rho}{r^2}[/tex]
Outside of the sphere, the electric field looks like that of a point charge with charge [tex]\frac{4}{3} \pi R^2 \rho[/tex], so we see that
[tex]E_{\text{outside}} = \frac{1}{4 \pi \epsilon_{0}} \frac{\frac{4}{3} \pi R^3 \rho}{r^2}[/tex].
We break our integral into an integration over the outside of the sphere and one over the inside of the sphere. This yields
[tex]\frac{1}{2} \epsilon_{0} \int d^{3}x E^2 = \frac{1}{2} \epsilon_{0} \left( \int_{0}^{R} dr 4 \pi r^2 \left[\frac{1}{4 \pi \epsilon_{0}} \frac{\frac{4}{3} \pi r^3 \rho}{r^2} \right]^2 + \int_{R}^{\infty} dr 4 \pi r^2 \left[\frac{1}{4 \pi \epsilon_{0}} \frac{\frac{4}{3} \pi R^3 \rho}{r^2} \right]^2 \right) =\frac{2 \pi R^5 \rho^2}{45 \epsilon_{0}} + \frac{2 \pi R^5 \rho^2}{9 \epsilon_{0}} = \frac{4 \pi R^5 \rho^2}{15 \epsilon_{0}}[/tex]
The two ways of doing it give you the same answer.
You don't get the same answer, because in the first way the energy is:
[tex]W=\frac{1}{2}\int \mathrm{d}^{3}r V(r)[/tex]
that is half what you get with the electric field way.
Maybe there's something wrong in the value of V(r) that I use in the integration (the same that you show in your calculations). Thank You
Claudio
You're right-- I see it now. The value for [tex]V(r)[/tex] inside of the sphere should instead be
[tex]V(r) = \frac{Q}{8 \pi \epsilon_{0} R} \left(3 - \left(\frac{r}{R}\right)^2 \right)[/tex]
where
[tex]Q = \frac{4}{3} \pi R^3 \rho[/tex]
which will give you the right answer when you correctly include the factor of [tex]\frac{1}{2}[/tex] in the integral over the potential.
  • · Replies 29 ·
