Acid theory - which ion does the donating?
  • Thread starter Thread starter zeta101
    Acid Ion Theory
The discussion centers on the concept of proton donation in ionic acids, specifically addressing whether the positive or negative ion acts as the proton donor in solution. It clarifies that in strong acids, which completely dissociate in water, the anion typically acts as the proton donor, while the cation remains positively charged or neutral. The conversation emphasizes that no acid can donate a proton and retain a positive charge, reinforcing the understanding of acid-base interactions in aqueous solutions.
  • Understanding of strong acids and their dissociation in water
  • Knowledge of acid-base theory, particularly Bronsted-Lowry theory
  • Familiarity with chemical structures and ionic compounds
  • Basic grasp of proton transfer mechanisms in aqueous solutions
  • Research Bronsted-Lowry acid-base theory in detail
  • Explore the dissociation of strong acids in aqueous solutions
  • Study the role of cations and anions in acid-base reactions
  • Investigate exceptions to typical acid-base behavior in chemistry
Chemistry students, educators, and professionals interested in acid-base chemistry and ionic interactions in solutions.
zeta101
I understand that with an ionic acid (when in solution), either the +ve ion OR the -ve ion can be the proton donor. Are there any ways to tell which ion does the donating by just looking at the chemical structure of the acid? I'd appreciate if someone could point me in the direction of an accepted theory that I can search for on the net.
Thanks
Chemistry news on Phys.org
your question doesn't make sense entirely
if you mean by "ionic acid" to say "strong acid"
as in one that 'completely' dissociates in water, then once it's in solution there will be protons hanging around water (H30+) and anions hanging around water
when a base comes along, it will just accept the proton
if you want to say that the original anion part of the "strong acid" was the donator then, I guess you could say that
there will be no acid that donates a proton and be left with a positive charge, it will either be negative or neutral
(if there is, that would be a weird exception that i am not aware of)
14K
