| Thread Closed |
Question: Resistors connected in parallel/ series |
Share Thread | Thread Tools |
| Sep20-09, 09:20 PM | #1 |
1.The equivalent resistance of several resistors connected in parallel is always lower than the smallest valued resistor. A) True B) False 2. The following two circuits are equivalent at terminals A-B. ![]() A) True B) False 3. For three resistors connected in series, the voltage across each resistor is equal even if the resistors have different values. A) True B) False ---- For number 1, I guessed True. I'm not sure but my reasoning behind is by KCL and KVL, voltages around a loop and current entering a node is zero at every instant. Again, I'm not sure about this one. For number 2, I guessed False. The cicuit on the left, I used Ohm's law to find its voltage; 50(v). On the other hand, the right circuit doesn't have a resistor at all. So I thought since 50(v) is greater than 0 (v) {the right circuit}, the statement is false, which states two circuits are equivalent. For number 3, I guessed True, because by the definition KVL, the sum of voltages around a loop equals zero. I'm confident about my answer for number 3, but I'm doubtful about 1 and 2. |
| Sep21-09, 01:08 AM | #2 |
Note: I'm commenting about your reasoning but not saying any of your answers are wrong...or right. It's not sufficient to guess correctly but to know why which I assume you already appreciate.
Number 1 start with the smallest valued resistor by itself. If you add another in parallel will the total resistance go up or down? Number 2 your reasoning looks good. In number 3 there is no mention of a loop. You have three resistors in series. That means current flowing through any one flows through them all so the currents are equal. How does this relate to the voltages? |
| Sep21-09, 01:35 AM | #3 |
For 1, the total resistance will go up.
For 2, I checked my textbook, and there is an example that shows a circuit and a equivalent circuit of its original circuit. Turns out, I was wrong. This one is actually True. For 3, that means the total voltage passing through each resistor is equal to the total resistance of the three resistors. R1 ---- R2 ---- R3 3ohms 4ohms 5ohms 3volts 4volts 5volts Therefore, it's false!! |
| Sep21-09, 03:36 AM | #4 |
Question: Resistors connected in parallel/ seriesNothing beats a nice concrete example to clarify! |
| Sep21-09, 09:47 AM | #5 |
About question number 2. You have an ideal current source. The current in terminal A will be 5A, whether there is a resistor in series or not.
| Sep21-09, 10:45 AM | #6 |
| Sep21-09, 11:00 AM | #7 |
| Sep21-09, 11:17 AM | #8 |
Hi Cathode,
for question 3. For three resistors connected in series, the voltage across each resistor is equal even if the resistors have different values. A) True B) False >>> The answer should be B) False. Different resistor value gives different voltage as the current is the same in series. |
| Sep21-09, 07:47 PM | #9 |
I'm still not understanding about question 1...
| Sep22-09, 04:57 AM | #10 |
| Sep22-09, 04:55 PM | #11 |
is the relationship, the product over sum rule?
| Sep22-09, 07:52 PM | #12 |
If there are two, then the more general expression R = 1/[(1/R1)+(1/R2)] will also be equal to R1 R1 / R1 + R2. But don't try using the product over the sum if there are three or more resistors. |
| Sep22-09, 08:24 PM | #13 |
[tex]R_{eq}=\frac{R_1R_2}{R_1+R_2}[/tex] Suppose [tex]R_2[/tex] is the smaller resistor. Divide the numerator and the denominator by [tex]R_1[/tex]. You get: [tex]R_{eq}=\frac{R_2}{1 + R_2/R_1}[/tex]. Since [tex]R_2[/tex] is divided by a quantity greater than 1, the result must be smaller than [tex]R_2[/tex]. You can consider the parallel of three resistors as the parallel of one with the equivalent of the parallel of the other two and so on. |
| Sep22-09, 09:20 PM | #14 |
ahh now I get it.
Thanks so much for the help, everyeon! |
| Thread Closed |
| Thread Tools | |
Similar Threads for: Question: Resistors connected in parallel/ series
| series and parallel resistors | Introductory Physics Homework | 2 | ||
| 2 resistors connected in parallel. same two in series what is the current? | Introductory Physics Homework | 16 | ||
| HELP! Resistors Parallel/series | Introductory Physics Homework | 3 | ||
| Resistors in series and parallel | Introductory Physics Homework | 3 | ||
| Resistors in series and parallel | Introductory Physics Homework | 6 | ||
