Factors affecting heat exchange
The discussion revolves around the factors affecting heat exchange, particularly in the context of thermodynamics. Participants explore various variables that influence heat transfer rates, including material properties and geometry.
  • Exploratory, Technical explanation, Conceptual clarification
  • One participant notes that surface area, temperature differentials, and exposure time are key factors in heat transfer.
  • Another participant suggests categorizing the influencing variables into material properties, geometry, and the driving force (temperature difference), mentioning specific properties like thermal conductivity, density, and specific heat capacity.
  • A participant inquires about recommended readings to learn more about the known factors affecting heat transfer.
  • A suggestion is made to refer to the textbook "Fundamentals of Heat and Mass Transfer" by Incropera and DeWitt as a resource.
Participants generally agree on the importance of various factors affecting heat transfer, but there is no consensus on a comprehensive list of all known factors, as the discussion remains exploratory.
The discussion does not resolve specific assumptions about the factors influencing heat transfer and lacks detailed exploration of each variable's impact.
Students and professionals interested in thermodynamics, heat transfer, and related engineering applications may find this discussion useful.
kateman
Heat transfer is something I've been interested in since studying thermodynamics last semester, although during the course we never really covered anything much to do with what affected heat transfer. I can pretty easily understand that obviously having a higher surface area to exchange across, temperature differentials and the time to which it is exposed will all affect the rate of transfer - but what else is there [if anything]?
Does what the material consists of or the shape of the material [other than to maximise contact with the thermal body] affect it?
Thanks for any insight =)
Science news on Phys.org
You can divide the variables into three areas: the material properties, the material geometry, and the driving force (the temperature difference). Sure, the material's thermal conductivity, density, specific heat capacity, and geometry, among others, could all play a part in the results.
is there anything you'd recommend for me to read to find out about all the known factors that affect heat transferance?
and thanks for your reply =)
Take a look at Incropera and DeWitt's Fundamentals of Heat and Mass Transfer. It's a textbook that's clear and useful enough to also serve as a handbook.
Thanks Mapes, i'll look into it!
  • · Replies 22 ·
  • · Replies 19 ·
  • · Replies 26 ·
  • · Replies 43 ·
9K
