Derive the expression for isothermal change in Constant Volume Heat Capacity
The discussion focuses on deriving the expression for the isothermal change in Constant Volume Heat Capacity, specifically the formula (dCv/dV)T = T(d2P/dT2)V. The participant begins with the ideal gas law, P = nRT/V, and calculates the first derivative (dP/dT) = R/V, leading to the conclusion that the second derivative (d2P/dT2) equals zero. Consequently, they deduce that (dCv/dV) results in zero, indicating no change in heat capacity with volume under the given assumptions.
  • Understanding of thermodynamics, particularly heat capacity concepts.
  • Familiarity with the ideal gas law and its applications.
  • Knowledge of calculus, specifically differentiation of functions.
  • Basic principles of isothermal processes in thermodynamic systems.
  • Study the derivation of heat capacity formulas in thermodynamics.
  • Explore the implications of the ideal gas law in different thermodynamic processes.
  • Learn about the significance of higher-order derivatives in thermodynamic equations.
  • Investigate the behavior of real gases compared to ideal gases under varying conditions.
Students and professionals in thermodynamics, particularly those studying heat capacity and gas laws, as well as educators teaching these concepts in physics or engineering courses.
eagerbeaver92
Derive the following expression for calculating the isothermal change in Constant Volume Heat Capacity:
I have no idea, please help
How about this?
assuming ideal gas:
P=nrt/V
then
(dP/dT) = R/V , ignoring moles
and
(d2P/d2T) = 0
so (dCv/dV)=T*0=0
  • · Replies 17 ·
