Discover the Most Likely Room Temperature for Jack's Heat Experiment
  • Thread starter Thread starter klng
    Heat
Jack's heat experiment involved two bottles of water at 20 degC, one wrapped in a wet washcloth and the other in a dry washcloth. After 20 minutes, the water temperature in the wet washcloth bottle was measured at 18 degC, while the dry washcloth bottle measured 22 degC. The most likely room temperature during the experiment is determined to be 21 degC, as the heat transfer dynamics indicate that the wet cloth absorbed heat, lowering the water temperature, while the dry cloth allowed for a slight increase.
  • Understanding of heat transfer principles
  • Knowledge of specific heat capacity
  • Familiarity with temperature measurement techniques
  • Basic concepts of thermodynamics
  • Research heat transfer mechanisms in liquids
  • Study the concept of specific heat capacity in detail
  • Learn about the effects of humidity on temperature readings
  • Explore thermodynamic principles related to heat exchange
Students studying thermodynamics, educators teaching heat transfer concepts, and anyone interested in experimental physics related to temperature measurement.
klng
Jack took two glass bottles containing water at 20 degC and wrapped them separately in washcloths. One of the washcloths was wet and the other was dry. Twenty minutes later, she measured the water temperature in each bottle. The water in the bottle with the wet washcloth was 18 degC, while the water in the bottle with the dry wash-cloth was 22degC. The most likely room temperature during this experiment was:
Choose one of the following options:
a) 26 degC
b) 21 degC
c) 20 degC
d) 18 degC
My predicted ans: 26 deg C. Heat has to go from a hotter environment to a cooler environment (i.e. 20 degC) to make one of the bottles (i.e. wrapped in dry cloth) attain a moderate temp of 22 deg C. For the one wraped in wet cloth, my guess is that water in the cloth is cooler than 20 deg C. Hence this wet wash cloth will absorb heat both from the environment, and the water, facilitated by water's high heat capacity.
Opinions on my reasoning?
Your reasoning is correct.
Thanks.
  • · Replies 28 ·
  • · Replies 23 ·
