The Energy Contained in a FunyunI must be mistaken?
  • Thread starter Thread starter Rhine720
    Energy
The discussion revolves around calculating the energy content in a Funyun, specifically focusing on determining the calories per gram and the total calories in a single Funyun. The subject area includes thermodynamics and calorimetry.
  • Participants discuss the setup of a homemade calorimeter to measure energy content and question the validity of the calculated calories per Funyun. There are inquiries about the conversion between calories and kilocalories, as well as the implications of food labeling.
The conversation is ongoing, with participants exploring different interpretations of calorie measurements and questioning the feasibility of the results obtained. Some guidance has been offered regarding the distinction between calories and kilocalories, but no consensus has been reached.
Participants note the absence of the weight of a Funyun, which is critical for accurate calculations. There is also mention of typical daily caloric intake, which raises questions about the realism of the energy content calculated for a single Funyun.
Rhine720
I'm required to find the amount of energy via calories in a single funyun and then calculate the amount of calories per gram.
Q=(M)C(deltaT)(Energy gained)
Q=M(deltaT) (Get Q in calories minus C because specific eat for water is same as joules per calory)
Calories per gram = calories /mass of food/1000
So I set up my home made Calorymeter(Had to make it) . So I lit it on fire and got managed to get a Delta Temperature. Then did Q=61gx(16.7) And got 1018.7Calories. But my problem is..Can a single Funyun contain 1000+ calories? Am I doing something wrong? I got 0.848 for calories per gram, which sounds reasonable..I may be right but I'm confused about this. Every funyun we eat contains 1k calories?..K i just multiplied 0.848 x 1.2 and got 1.0716 ..Does this have something to do with the bag having a Capital C for 1k calories and what not?
Food labels have kilocalories on them. 1 Kcal = 1000 calories = 4.2 KJ.
1 kcal for each funyun seems plausible, maybe even too low. Pure fat is about 9 kcal/g. Carbohydrates 4 kcal/g. Whats the weight of a funyun?
You have 1018 Calories for each funyun, but .848 calories per gram. The second number must be kilocalories.
I'm did not weigh the funyun. =/ However If those most a healthy person is to eat in a day is 2000-300o calories then how does can a 1018 calory funyun even be realistic?
Of course those are 2000-3000 kilocalories as well. so if a funyn really has 1018 calories is 1.018 kilocalories, you could eat 2000 a day.
Were you actually instructed to find the calories this way? Could you not just read the Calories and weight info from the package?
Also (as willem2 said) 1 food Calorie = 1000 calories
Note the uppercase "C" is used for food Calories.
9K
  • · Replies 18 ·
