Help questions on electricity and magnetism
The discussion revolves around questions related to electricity and magnetism, specifically focusing on magnetic fields, magnetic flux, and RL circuits. Participants are exploring concepts such as the relationship between electric and magnetic fields, the calculation of magnetic flux, and the behavior of current in an RL circuit.
  • Exploratory, Conceptual clarification, Problem interpretation
  • The original poster attempts to determine the frequency of a magnetic field given its strength and the strength of an electric field. They also seek clarification on the angle to use in calculating magnetic flux through a surface, questioning their previous angle choices. Additionally, they inquire about the inductance in an RL circuit and the time it takes for the current to reach a certain value, expressing frustration over their attempts to apply formulas.
Some participants have provided guidance by suggesting that the original poster consider the physical principles behind the problems rather than solely relying on formulas. There is an acknowledgment of the need to incorporate voltage in the RL circuit problem, indicating a productive direction in the discussion.
Participants are working under the constraints of homework assignments, which may limit the information they can share or the methods they can use. There is an emphasis on understanding the underlying concepts rather than simply applying formulas.
supermenscher
help! questions on electricity and magnetism
1. What is the frequency of the magnetic filed if it is know to be perpendicular to the electric field. The magnetic field is 0.00178T and the electric field is 8000V/m.
2. I just need the angle for this one. At a certain location, the Earth's magnetic field has a magnitude of 5.6E-5T and points in a direction that is 72 degrees below the horizontal. Find the magnitued of the magnetic flux through the top of a desk at this location that measures 110cmX73cm.
I know you used magnetic flux = BAcos theta...but what is the angle theta, I tried 72 degrees and 18 degrees, what angle do I use?
3. When the switch is closed in a RL circuit the current in the circuit increases from 0A to 0.22A in 0.15s. This current also has a resistance of 5.5 ohms. What is the inductance L, how long after the switch is closed does the current have a value of 0.41A, and what is the maximum current that flows in the cirucit.
I have tried this problem using every formula possible and still can't get it...can someone help me out, even to get me started? Thank you.
I want to know if in problem 3 you're forgetting the voltage (emf).
wisky40
Yes, sorry the voltage is 9.0V
I think your problems start from there. Stop thinking in formulas and start thinking physically. You are given the rate the current changes. Changing current causes a changing magnetic field (Hint: think faraday's law).
  • · Replies 37 ·
  • · Replies 49 ·
