Need the parametric equation of a circle perpendicular to a vector.
The discussion revolves around finding a parametric equation for a circle in 3D space that is perpendicular to a given vector . Participants explore the relationship between the intersection of a plane and a sphere, as well as implications related to Stokes' Theorem.
  • Exploratory, Technical explanation, Conceptual clarification, Debate/contested
  • One participant seeks a parametric equation of a circle in the form x[t], y[t], z[t] that is perpendicular to the vector .
  • Another participant rephrases the problem as finding the intersection of the plane ax + by + cz = 0 and the sphere x^2 + y^2 + z^2 = constant.
  • A suggestion is made to solve for z in the plane equation and substitute it into the sphere's equation to derive an xy equation that represents an ellipse, which can then be parameterized.
  • A later reply adds complexity by noting that the resulting equation in the xy plane may involve translation and rotation, and questions the necessity of a circuit integral in the context of Stokes' Theorem.
  • Another participant expresses a desire to prove that the magnitude of curl corresponds to the line integral around a region perpendicular to the curl vector.
Participants present multiple competing views on how to approach the problem, and the discussion remains unresolved regarding the best method to derive the parametric equations.
Participants acknowledge the complexity of the problem, including potential translations and rotations of the ellipse in the xy plane, and the implications of Stokes' Theorem without providing specific details of the problem at hand.
okkvlt
i need a parametric equation of a circle in 3d space that is perpendicular to a vector <a,b,c>. (as t goes up the circle is traced counterclockwise, as viewed from the head of the vector.)
in the form x[t],y[t],z[t]
i know that x^2+y^2+z^2=constant
and that ax+by+cz=0
But i cannot figure out the parametric equation x[t],y[t],z[t] that describes a circle perpendicular to the vector.
or, phrased in other words, this is the intersection of the plane ax+by+cz=0 and the sphere x^2+y^2+z^2=constant.
in case anybodys wondering, I am working on stokes theorem.
There may be a shorter way in some specific cases, but you might try this. Solve the plane for z and put that in the equation of the sphere. This will give you an xy equation which represents the projection of the intersection curve in the xy plane. This will be an ellipse. Complete the square on it and get it in the standard form:
[tex]\frac {(x-p)^2}{a^2} + \frac {(y-q)^2}{b^2} = 1[/tex]
Then you can parameterize it as:
[tex]x = p + a\cos(t)\ y=q + b\sin(t)[/tex]
and use these to get z on the plane in terms of t also.
I want to add, after thinking about my reply, that it isn't so simple. The equation in the xy plane will likely be both translated and rotated. And since the OP is working with Stoke's Theorem, my guess is that the circuit integral might be unnecessary and, depending on the specific problem, the surface integral that Stoke's theorem gives may be easy. Hard to say without seeing the specific problem.
i want to prove that the magnitude of curl is the line integral around a region perpendicular to the curl vector.
  • · Replies 0 ·
