Is an AC battery charger effective for charging batteries?
  • Thread starter Thread starter NotoriousNick
    Charger
An AC battery charger is generally ineffective for charging batteries directly due to the nature of alternating current. However, incorporating a diode that conducts in the correct direction can enable the charging process. A specific circuit example is necessary to provide a more conclusive solution. This discussion highlights the importance of circuit design in utilizing AC for battery charging.
  • Understanding of AC and DC current principles
  • Knowledge of diode functionality and types
  • Familiarity with basic circuit design
  • Experience with battery charging methods
  • Research circuit designs for AC battery charging with diodes
  • Learn about different types of diodes and their applications
  • Explore the principles of rectification in electrical engineering
  • Investigate battery chemistry and charging requirements
Electrical engineers, hobbyists in electronics, and anyone interested in battery charging technologies.
NotoriousNick
AC battery charger?
Is there such a thing as being able to charge a battery, using alternating current, or would the sweeps invariably be ineffective in giving a charge to the battery?
As you suspect, that would be ineffective. But adding a diode that conducts in the appropriate direction would probably solve the problem. (We would need to see a specific circuit example in order to give a more definitive answer.)
