Explaining Windows Memory Paging and Allocation
  • Thread starter Thread starter martix
    Memory Windows
The discussion centers on Windows memory paging and allocation, specifically addressing why Windows utilizes swap/pagefile even when ample physical memory is available. The primary reason is that swapping out infrequently used memory is time-efficient, allowing Windows to manage memory dynamically. This strategy enables the operating system to free up RAM for active processes while retaining a swapped copy for potential future use. Additionally, the discussion highlights that physical memory rarely reaches full capacity, often remaining around 19-- MB, due to the operating system's memory management techniques.
  • Understanding of Windows operating system memory management
  • Familiarity with paging and swap/pagefile concepts
  • Knowledge of memory allocation strategies in modern operating systems
  • Basic comprehension of physical vs. virtual memory
  • Research Windows memory management techniques and algorithms
  • Learn about the Windows page replacement algorithm
  • Explore the impact of physical memory limits on application performance
  • Investigate tools for monitoring memory usage in Windows, such as Resource Monitor
System administrators, software developers, and IT professionals seeking to optimize Windows memory performance and understand the intricacies of memory allocation and paging behavior.
martix
I have wondered for quite a while why memory allocation and paging in Windows seems to be so weird and doesn't want to use memory to the fullest.
For example even when there is a lot of free physical memory, there are sections that are paged out.
And then - physical memory never seems to fill up totally.
I'd appreciate someone explaining the reasons behind this behavior.
Technology news on Phys.org
It's a complex subject -
The main reason it uses swap/pagefile when there is free ram is that swapping out memory is cheap (in time) compared to getting it back, so when you have some memory that doesn't look like it's changing very often Windows (and most modern OSs) will swap it out when they aren't busy. If they then need some more memory for another task they can quickly delete the in-memory copy of the other data because they already have a swapped copy. Of course when the other process needs that memory it will have to be read back in - but that's a problem for the future.
Let me see if I got this:
Basically while windows is idle it uses the time to copy infrequently used data to HDD, so if the need arises for lots of memory, it can just delete the memory copy, without the effort of swapping it first.
If this is right, then it does make a lot of sense and is actually a cool idea, provided the page replacement algorithm knows its job...
Then there's the other extreme - why does it not use the entire physical memory space?
For example I have 2048MB of memory and I have never seen it reach 2000MB physical usage(always ~19-- MB).
  • · Replies 22 ·
