| New Reply |
FORTRAN, open several files and read it |
Share Thread | Thread Tools |
| Sep29-09, 07:55 AM | #1 |
Hi pals I'm using fortran program to open several files like iso1.dat,iso2.dat.... iso9.dat withis this files are number that I can read with my program, but I dont know how can I open the files above and then read it
this is my simple code Code:
implicit real*8(a-h,o-z)
parameter(nx=100)
dimension y(nx),eta(nx),iso(nx)
integer::nl1,i,n
character*60 dumi
nl1=9
do i=1,8
open(10,file='iso00.dat')
end do
do i=1,nl1
read(10,fmt=*)dumi
end do
DO n=1,5
read(10,fmt=*)i,y(n),eta(n),j,k,p,q,s
write(*,'(2d14.6)')y(n),eta(n)
END DO
stop
end
| Sep29-09, 01:25 PM | #2 |
Mentor
In this code
Code:
do i=1,8
end do
| Sep29-09, 02:34 PM | #3 |
Recognitions:
There are a couple ways of opening files in a DO loops. The easiest is to just open them prior to the DO loop, and then just reading unit number of the do iterator, e.g.
Code:
OPEN(11,file....) OPEN(12,file....) OPEN(13,file....) OPEN(14,file....) .... DO i=1,4 ii = i + 10 READ(ii,*) .... ... END DO ... |
| Sep30-09, 07:09 AM | #4 |
FORTRAN, open several files and read itCode:
DO I=1,400 OPEN(I,file=' ISO????.DAT'....) HERE IS MY PROBLEM HOW CAN I OPEN FILES AS ISO1,ISO2....ISO400 END DO .... DO i=1,4 ii = i + 10 READ(ii,*) .... ... END DO ... |
| Sep30-09, 07:20 AM | #5 |
Recognitions:
I had actually started a thread a little while back that you can see below in the similar threads. You'll basically want something like:
Code:
CHARACTER(len=12) :: FN
N=5 !--arbitrary number of files
DO I=1,N
WRITE(FN,10)I
WRITE(6,*)FN
OPEN(1,FILE=FN)
CLOSE(1)
END DO
10 FORMAT('ISO',I2.2,'.DAT')
STOP
END
| Sep30-09, 08:44 AM | #6 |
following your tips I compile the program and it worked, but I need to read and stored the dates in another file,well I thought It wouldn't difficult but I was wrong, so further details of my code is
Code:
parameter(nx=100)
integer::nl1,i,j,k
character(len=12)::fn
n=5 !arbitrary number of files
nl1=9
10 format('iso',i2.2,'.dat')
do i=2,n
write(fn,10)i
write(6,*)fn
open(1,file=fn)
do j=1,nl1
read(1,fmt=*)dumi THIS LINE READ THE CHARACTERS
end do
do k=1,5
read(1,fmt=*)w,y(k),eta(k),p,q,s,t,r THIS LINE SHOULD BE STORE MY DATAS IN 2 VECTORS
end do
close(1)
end do
stop
end
any tip to help me please RG |
| Sep30-09, 12:15 PM | #7 |
Recognitions:
I can't really understand what you're trying to do. Can you try to explain a little better?
| Sep30-09, 06:07 PM | #8 |
Recognitions:
400 files takes 3 digits, so that format should be
10 format('iso',i3.3,'.dat') |
| Oct1-09, 06:36 AM | #9 |
Im gonna explain what I need to do.
First I would like to open 400 files e.g ISO1.dat,..ISO400.dat, within this files I have datas which means numbers for instance( X,Y,Z are vectors) ISO1.dat has X1,Y1,Z1 vectors ISO2.dat has X1,Y2,Z2 vectors ISO3.dat has X1,Y3,Z3 vectors I only need to read X and Y then write in a unique file X1,Y1,Y2,Y3...Y400 How Can I do it Hope to be clear this time Tks |
| Oct1-09, 07:46 AM | #10 |
Recognitions:
As Jeff mentioned, it'll be a lot easier if your files are ISO001, rather than just ISO1. Using that method, you can just open another file
Code:
PROGRAM
IMPLICIT NONE
INTEGER :: n
REAL,DIMENSION(:),ALLOCATABLE :: x,y,z
n=400
OPEN(11,file='output.dat',form='formatted')
!--allocate your vectors here
DO I=1,N
WRITE(FN,10)I
WRITE(6,*)FN
OPEN(1,FILE=FN)
READ(1,*) x,y,z
WRITE(11,*) x,y
CLOSE(1)
END DO
10 FORMAT('ISO',I3.3,'.DAT')
DEALLOCATE( x,y,z )
END PROGRAM
| Oct1-09, 09:25 AM | #11 |
hey thanks for your replied, One more question since my vector X,Y,Z has 5 elements so what I need to do is a loop
Code:
PROGRAM
IMPLICIT NONE
INTEGER :: n
n=400
DO I=1,N
WRITE(FN,10)I
WRITE(6,*)FN
OPEN(1,FILE=FN)
DO j=1,5
READ(1,*) x(J),y(J),z(J) HERE I STORED MY VECTORS WITH ITS ELEMENTS
WRITE(11,*) x(J),y(J)
END DO
CLOSE(1)
END DO
DEALLOCATE( x,y,z )
END PROGRAM
Many thanks |
| Oct5-09, 08:00 AM | #12 |
Hi Pals I got to read the files finally :-) and the write in one file in this case output.dat
[code\] PROGRAM eta implicit none integer ::n,i,j real,dimension(:),allocatable::x,y,z,u,v,w,p,f character(len=12)::fn n=3 !NUMBER OF FILES open(11,file='output.dat',form='formatted') !allocate your vectors here allocate (x(5),y(5),z(5),u(5),v(5),w(5),p(5),f(5)) DO i=1,n !LOOP FOR THE NUMBER OF FILES write(fn,10)i write(6,*)fn open(1,file=fn) do j=1,5 read(1,*)x(j),y(j),z(j),u(j),v(j),w(j),p(j),f(j) write(11,*)y(j),z(j) end do close(1) END DO 10 format('iso',i3.3,'.dat') deallocate(x,y,z,u,v,w,p,f) END PROGRAM eta [code] but I have one problem in the output I wrote vector X1 three times and then vector Y1 follow Y2 and Y3 in one column, I would like to write it in this shape X1 Y1 Y2 Y3....Y400 it means 400 columns Can you suggest me something I am really close what I want, just I need a bit help please |
| Oct5-09, 12:43 PM | #13 |
Recognitions:
Rather than having your write statement inside your second DO loop, just put it after, e.g.
Code:
DO i=1,n !LOOP FOR THE NUMBER OF FILES write(fn,10)i write(6,*)fn open(1,file=fn) do j=1,5 read(1,*)x(j),y(j),z(j),u(j),v(j),w(j),p(j),f(j) end do close(1) END DO write(11,*)x(1),y(:) ... |
| Oct7-09, 03:32 PM | #14 |
Code:
-20.50000 -13.50000 -6.500000 7.500000 14.50000 this is Y1 1.450721 1.410950 1.247190 1.258387 1.406754 this is Z1 -20.50000 -13.50000 -6.500000 7.500000 14.50000 this is Y1 1.320300 1.294613 1.176677 1.187839 1.292512 this is Z2 -20.50000 -13.50000 -6.500000 7.500000 14.50000 this is Y1 1.228186 1.202048 1.076701 1.095856 1.203530 this is Z3 |
| Oct7-09, 03:59 PM | #15 |
Recognitions:
You should really get a Fortran book and start from page 1. In order to write those as a column and not a row, you can loop over the vector writing out a single entry each time.
In fact, that's what you were doing in post 11. If you want, you can use a counter variable and store the entire XYZ values (all of them from each file) in a separate file, and write it out at the end....the possibilities are numerous. |
| Oct7-09, 04:32 PM | #16 |
[code] -20.50000 1.450721 -13.50000 1.410950 -6.500000 1.247190 7.500000 1.258387 14.50000 1.406754 -20.50000 1.320300 -13.50000 1.294613 -6.500000 1.176677 7.500000 1.187839 14.50000 1.292512 -20.50000 1.228186 -13.50000 1.202048 -6.500000 1.076701 7.500000 1.095856 14.50000 1.203530 [\code] all together but this is what I don't wish, I want Y1,Z1,Y1,Z2,Y1,Z3 or if I could get to write it as:Y1,Z1,Z2,Z3 would be better but I dude that i can write it out in that way, anyway FORTRAN is a big complicated |
| Jun17-10, 11:45 PM | #17 |
Thanks for your discussion which was really helpful to my work.... AND THANKS TO PHYSICS FORUMS
| New Reply |
| Thread Tools | |
Similar Threads for: FORTRAN, open several files and read it
| Python: open dat-files, read data | Engineering, Comp Sci, & Technology Homework | 5 | ||
| FORTRAN Open Arbitrary number of files in Do Loop | Programming & Comp Sci | 8 | ||
| Loading 2D array files to Fortran variables | Programming & Comp Sci | 12 | ||
| Fortran 90 (need to read in binary data files into arrays) | Math & Science Software | 1 | ||
| Fortran 90 question about reading files with text | Programming & Comp Sci | 1 | ||
