Proving Inequalities: Multiplying 2 Negs Becomes a Positive
  • Context: High School
  • Thread starter Thread starter Whatever123
    Inequalities
The discussion revolves around the mathematical concept of why the product of two negative numbers results in a positive number. Participants explore various proofs and reasoning behind this property, as well as the related question of why inequalities flip when dividing by a negative number. The scope includes mathematical reasoning and conceptual clarification.
  • One participant presents a proof involving positive numbers and the manipulation of inequalities to show that multiplying two negatives results in a positive.
  • Another participant questions the clarity of the proof and suggests that the order of operations does not affect the outcome, emphasizing the importance of focusing on signs rather than actual values.
  • Some participants express preferences for different approaches to the proof, indicating that multiple methods can illustrate the same concept.
  • Concerns are raised about the necessity of dividing in the proof, with suggestions that alternative methods could yield the same conclusion without division.
  • There is a discussion about the implications of dividing by a negative number and how it relates to the flipping of inequalities.
Participants do not reach a consensus on the best method to prove that the product of two negatives is positive. There are multiple competing views on the proofs and approaches discussed, and the reasoning behind dividing by negatives remains unresolved.
Some participants note that the clarity of the proof could be improved, and there are mentions of typos that could affect understanding. The discussion also highlights the dependence on definitions and the assumptions made in the proofs presented.
Whatever123
Ok... So today, someone asked me a simple question: Why do two negatives become a positive number when multiplied together? This is intuitively basic, but not as easy to prove (unless there's some simple proof that I didn't think of). This was the basic proof that I came up with:
Let a, b, c > 0 and a, b, c [tex]\in[/tex] R.
a > 0
a/(-b) < 0/(-b)
a/(-b) < 0
a/(-b)(-c) > 0/(-b)(-c)
a/(-b)(-c) > 0
Since a/(-b)(-c) is greater than 0, and a is positive, then (-b)(-c) must also be positive. Therefore, multiplying by two negatives will produce a positive.
I know my proof isn't very good, but I am not a mathematician. I thought that I came up with a semi-decent way to show that multiplying two negatives together will produce a positive number. Now, the next question that person asked me was: Well then why does the inequality flip over when you divide by a negative? Again, it's intuitively obvious but I do not know how to prove it. Does anyone know how I could prove that or a better way to prove what I just attempted to prove?
P.S. I meant to put this in general math because it would be more appropriate there, but I accidently posted it here and cannot delete it. So maybe a moderator can move it...
a > 0
a/(-b) < 0/(-b)
a/(-b) < 0
Is this a/((-b)(-c)) or (a/(-b))(-c)?
a/(-b)(-c) > 0
Of course, you use "if c< 0 and a> b then ac< bc" extensively. That doesn't seem to me to be more obvious than "negative times negative is positive" itself. That would be proved by "If c< 0 then (-c)> 0. If also a> b then a(-c)> b(-c) or -(ab)> -(ac). Now add ab and ac to both sides: ab+ ac- (ab)= ac> ab+ ac- (ac)= ab." Immediately from that follows "negative times negative equals positive": if a< 0 and b< 0, then ab> 0b= 0.
Doesn't matter... It works out the same...
Thanks for the advice... I'll keep that in mind when trying to expand my current proof...
Why did you divide?
Couldn't you get the same thing with
-a < 0
(-a)(-b) > 0(-b) = 0
Bingk said:
Why did you divide?
-a < 0
I divided because it doesn't really make a difference to the proof and it's easier on me. I wanted to show that a/((-b)(-c)) > 0. Since the numerator, by definition, is greater than 0, then the denominator must be greater than 0. I thought it would be an easy way to look at it since you're looking at a, and (-b)(-c) separately. I wanted to organize it so that you could look to the top of the fraction for one and the bottom for the other...
24/((-8)(-3)) < (24/(-8))(-3) so I don't understand why you say it doesn't matter what order you preform the operations.
Ah, okay ... I get why you did it, but I still prefer my way ;), hehe. I guess it just depends how you want to see it ... my way shows that the product of 2 negatives is greater than 0.
As for ramsey2879, I think Whatever123 meant that it doesn't matter in the sense that they are both greater than zero ... but if you consider Whatever123's response to my question, then really, it should be a / ((-b)(-c)), so that the denominator is a product of two negatives :)
I'm saying that it doesn't matter in my proof because I do not care what the actual value is; I just care about if it's greater or less than 0. I'm just worried about the signs, not the value. So it does work out the same for my proof.
Yes. That was an original typo mistake that I simply missed. I updated it when I responded to you.
  • · Replies 25 ·
  • · Replies 19 ·
