Calculating Work Done on Moving Object: Initial vs Final Velocity
The discussion centers on the calculation of work done on a moving object, specifically comparing scenarios with initial and final velocities. When a force is applied to an object initially moving at 5 m/s until it stops, the work done is calculated as 0.5m(0)² - 0.5m(5)², resulting in a negative value due to the opposing force. Conversely, when a stationary object is accelerated to 5 m/s and then stops, the net work done is zero, as the work done by the applied force and the resistive force balance out. The key takeaway is that work is determined by the change in kinetic energy, focusing solely on initial and final velocities, regardless of the distance traveled.
  • Understanding of Newton's laws of motion
  • Familiarity with the concept of kinetic energy
  • Knowledge of work-energy principle
  • Basic grasp of forces and motion dynamics
  • Study the work-energy theorem in classical mechanics
  • Learn about the effects of frictional forces on work done
  • Explore the relationship between force, mass, and acceleration
  • Investigate the implications of resistive forces in motion scenarios
Physics students, educators, and anyone interested in understanding the principles of work and energy in mechanics.
MechaMZ
An object is moving with an initial velocity 5m/s, if I'm applying a force against it and it stops after a displacement.
So the work done is equal to 0.5m(0)2-0.5m(5)2
A stationary object, 0m/s, if I'm applying a force to it and it moves with a velocity of 5m/s, and stop after the force removed.
So the work done is equal to zero? 0.5m(0)2-0.5m(0)2=0
Should it be zero? and why it is zero? the object did travel a distance isn't?
definition: Work is a measure of change of energy.
So does it mean no matter how far an object moved, or how fast it has moved, we only consider the initial velocity and final velocity?
for eg, an object moved from stationary, speed up to 2m/s for 30min, then slower down to 1m/s and speed up to 5m/s for 1 hour, then finally it stop and remain stationary again. the work done in this case is also considered as zero?
if i apply a force on a stationary object, and it move a certain time after the force has removed. should i take the zero as initial velocity or the instantaneous velocity when the force just applied on it?
Please help, I'm very confused. thank you
I think you are confused over the idea of work done on the body, and work done by the forces.
Let's say I apply a constant force on a body to accelerate it from rest to a speed v over a smooth surface. Then, assuming that no resistive forces exist, work done by the force on the body is equal to the total net work done on the body, 0.5mv2. Then I remove this force, and it continues moving in a straight line with velocity v. For it to come to a stop, a resistive force must act on it. So, we let the body move over a rough surface. Thus, the frictional force does negative work on the body (since it is opposite in direction to the body's displacement) - i.e. extracting energy from the body. When the body comes to a rest, then you are right in saying that the net work done on the body is zero. The work done by each force on the body is however not zero, and total net work done on the body is the sum of the work done on the body by each force.
  • · Replies 28 ·
  • · Replies 28 ·
