How and why does everything in life reach equilibrium?
  • Context: Undergrad
  • Thread starter Thread starter sameeralord
    Equilibrium Life
The discussion revolves around the concept of equilibrium in various scientific contexts, including pressure, electricity, and concentration. Participants explore why systems tend to reach equilibrium, the role of energy in this process, and the implications of these ideas in both physical and living systems.
  • Some participants suggest that systems reach equilibrium to minimize energy, with one noting that extremes can be harmful and equilibrium is necessary for survival.
  • Others argue that systems do not necessarily "know" where to go, but rather tend to wander and settle in the most probable state due to random interactions.
  • A participant mentions that particles lose energy to move from high to low energy states, while another states that energy is redistributed rather than gained or lost.
  • One contribution highlights that not all systems strive for the lowest energy state, using examples like water and air to illustrate exceptions.
  • Another participant points out that living systems exist in far-from-equilibrium conditions, complicating the notion of equilibrium.
  • There is a playful exchange about the poetic nature of the discussion, indicating a lighter tone amidst the technical content.
Participants express multiple competing views regarding the reasons systems reach equilibrium and the nature of energy transfer. The discussion remains unresolved, with no consensus on the underlying mechanisms or definitions of equilibrium.
Some limitations include the ambiguity in definitions of equilibrium and the varying contexts in which it applies, such as in living versus non-living systems. The discussion also reflects differing interpretations of energy dynamics and entropy.
sameeralord
Hello,
In science there are so many equilibrium concepts. Pressure, electricity ,concentration...
Everything seems to be moving from high to low to reach equilibrium
My questions are
1. Why does everything try to reach equilibrium? (Extremes are generally harmful and for survival of this word equilibrium is required is that the reason)
2. From where do the particles get energy to move from high to low and how do they know they have to move from high to low to reach equilibrium.
Thank you very much!
Everything tries to reach a state where its energy (total energy, maybe thermal, electrical, potential, whatever) is minimum.
Contrary to what you quote, particles have to *lose* energy as opposed to *get* energy to move from high to low. And as we all know, losing is easier than gaining. How they know which state has the lowest energy and where they need to go is much more involved and would involve discussions on entropy and geometry.
Thanks tanujkush for the reply. :smile: It is afterall a natural process.
If you dig the question a bit, the first answer is: we call in fact "equilibrium", the "most probable state". If you dig the question even more, the answer is that we don't really know :smile: but it is probably best to stop just before reaching this conclusion. :biggrin:
Not always, and in all circumstances, systems try to reach "equilibrium", but most of the time they do, and that comes about because, contrary to what you seem to think, the "system" doesn't "know" anything of where it "has to go" and its interactions make it wander of eratically. Now, if you wander off eratically, chances are that you will end up in the "biggest chunk" of possibilities, and that's nothing else but the "equilibrium state".
Consider it this way: suppose your system is 100 dice in a (big) jar. Now, if you throw the dice, and you make the sum of all outcomes, then the outcome "100" is extremely rare, because there is only ONE dice configuration that can do this (all dice must be "1"). In the same way, the outcome "600" is extremely rare, because again, only one dice configuration can do that (all dice must be "600").
But 350 is the most probable, because it has the most different possible dice configurations that sum to 350. So the "equilibrium" sum must be somewhat around 350.
It is only if the motions of the dice in the jar would somehow "know what to do" that you could deviate from this. Randomly thrown dice will tend to have a sum around 350, simply because there are more different configurations of them leading to that sum than to any other. So "350" corresponds to the biggest "chunk" in "configuration space" (or "possibility space of the system").
They exchange energy with one another. Some win, some loose, and the distribution of energy over the different constituents is one of the things that will settle in "most probable" configuration.
edit: btw, it is not in general true that "systems try to reach lowest energy". Otherwise, all water would freeze, all air would liquify etc...
sameeralord said:
Hello,
My questions are
1. Everything tries to reach equilibrium because the whole thing (system ) will get higher entropy.
2. Energy is not lost or gained, it just moves from high energy parts to low energy ones.
sameeralord said:
Hello,
My questions are
"equilibrium" has a simple definition, but in practice, is not so obvious. Living matter, for example, is maintained at far-from-equilibrium conditions. Physical structures may seem to be in equilibrium, but "how long do you want to wait"? mountains erode, continents move, orbits decay.
Even so, since we can be very quantitative about "how long we want to wait", equilibrium is a very useful concept. To answer your specific questions:
1) Because everything in the universe is lazy and tends to a minimum in energy.
2) Unless there is an energy barrier present, systems to not need to acquire energy to reach a minimum- they are losing energy. And systems tend to lose energy because of (1).
Hum, that sounds like the beginning of a lyric :smile:
but my love for you will always stay
tadum dadum tadum ...
:smile:
(hum, sorry).
:smile:
(hum, sorry).
:cool:
Thanks for all the answers :smile:
  • · Replies 23 ·
  • · Replies 109 ·
10K
