Show that the voltage across resistor R2
  • Thread starter Thread starter KillerZ
    Resistor Voltage
The discussion revolves around a circuit problem involving resistors and the application of power conservation principles. Participants are tasked with demonstrating the voltage across resistor R2 using the relationship between supplied and absorbed power.
  • Participants discuss the application of power conservation, with attempts to relate the supplied power to the power absorbed by the resistors. Questions arise regarding the correct use of Ohm's law and the implications of the absence of internal resistance in the voltage source.
The discussion is ongoing, with participants exploring different interpretations of the problem. Some have provided guidance on applying Ohm's law, while others are questioning the setup and relationships between the circuit components.
Participants note the absence of internal resistance in the voltage source as a key aspect of the problem. There is also a focus on the total resistance and current in the circuit, which may influence the understanding of voltage across R2.
KillerZ
In the circuit shown, the same current must flow through all three componets as a result of conservation laws. Using the fact that the total power supplied equal the total power absorbed, show that the voltage across resistor R2 is given by:
[tex]v_{R_{2}} = v_{s}\frac{R_{2}}{R_{1} + R_{2}}[/tex]
[tex]p = vi = i^{2}R = \frac{v^{2}}{R}[/tex]
I said:
[tex]p_{v_{s}} = p_{R_{1}} + p_{R_{2}}[/tex]
because power supplied = power absorbed
But I don't think this is right because it would not simplify right.
[tex]v_{s}i = i^{2}R_{1} + \frac{v_{R_{2}}^{2}}{R_{2}}[/tex]
Since total power supplied is equal to the total power absorbed, there is no internal resistance in Vs.
Apply the ohm's law to the circuit and find VR2.
I am still having trouble with this.
I know Ohm's law is
[tex]v = IR[/tex]
[tex]I = \frac{v}{R}[/tex]
and
[tex]R = \frac{v}{I}[/tex]
but do I just just use them with this:
What is the total resistance in the circuit?
What is the current in the circuit?
And then what is the voltage across R2?
Here you need not use the power formula.
In the problem the mention of the power is to emphasis the absence of internal resistance in the source.
  • · Replies 30 ·
  • · Replies 22 ·
