| Thread Closed |
Force needed to pull a block up an incline. |
Share Thread | Thread Tools |
| Sep30-09, 03:13 PM | #1 |
Calculate the force needed to pull a mass of 20 kg at a uniform slow speed up a plane inclined at an angle of 30 with the horizontal if the coefficient of kinetic friction is 0.20. 2. Relevant equations WN= w cos [tex]\vartheta[/tex] WT= w sin [tex]\vartheta[/tex] [tex]\mu[/tex]s= tan[tex]\vartheta[/tex] 3. The attempt at a solution I don't even know how to get started. |
| Sep30-09, 07:38 PM | #2 |
If the block is moving at a constant speed then you know that there is no net force acting on the block.
| Sep30-09, 08:56 PM | #3 |
so the friction force is
(.2)(20)(9.8)(cos 30) ? and the gravitational force is (20)(9.8)(sin 30) ? i got 34 N for friction and 98 N for gravitational. are they supposed to equal zero? or do i add them together to find the force i need to overcome? or could i just overcome the strongest? |
| Oct1-09, 05:31 AM | #4 |
So what force is needed to make them balance?
| Oct1-09, 08:26 AM | #5 |
okay, so 34 N for friction pull the box up the slope, and 98 N gravity pull down.
98 N - 34 N = 64 N needed to equalize them, and more than 64 to make it move uphill? |
| Oct2-09, 07:22 AM | #6 |
What direction will the friction be acting in if the box is being pulled up the slope?
| Oct2-09, 07:49 AM | #7 |
Recognitions:
What is the direction of the force applied and whether the friction will depend on that direction.
| Oct2-09, 07:57 AM | #8 |
Recognitions:
If the minimum force needed is required than the force must be applied at an angle equal to angle of friction [tan^-1 (u)] with the incline.
| Thread Closed |
| Thread Tools | |
Similar Threads for: Force needed to pull a block up an incline.
| block on incline with vertical force | Introductory Physics Homework | 10 | ||
| Block sliding down an incline and hitting a smaller block | Introductory Physics Homework | 7 | ||
| A 2.5 kg block and a 3.1 kg block slide down a 30 degree incline. | Introductory Physics Homework | 10 | ||
| Force needed to keep block from moving on frictionless triangular block | Introductory Physics Homework | 1 | ||
| force needed to push box down incline plane | Introductory Physics Homework | 3 | ||
