Newton's Laws - friction, tension, acceleration
The discussion revolves around a physics problem involving Newton's Laws, specifically focusing on friction, tension, and acceleration of two blocks connected by a string and subjected to a pulling force. The problem presents equations for the forces acting on each block and seeks to determine the acceleration and tension in the string.
  • Mixed
  • Participants discuss setting up equations based on Newton's second law for each block, with attempts to solve for tension and acceleration. There are inquiries about the correctness of the arithmetic and the approach taken in combining the equations.
The discussion is ongoing, with participants sharing their attempts at solving the equations and questioning the arithmetic involved. Some guidance has been offered regarding checking calculations, but no consensus on the correct answer has been reached.
Participants are working under the constraints of a homework assignment, which may limit the information they can share or the methods they can use. There is an emphasis on ensuring the equations are set up correctly and that calculations are accurate.
buckybadger
Newton's Laws -- friction, tension, acceleration
A block of mass m1 = 2 kg and a block of mass m2 = 3 kg are tied together and are pulled from rest across the floor by a force of Fp = 24 N. The coefficient of friction of the blocks with the floor is μ = 0.27.
a) What is the acceleration of the two blocks?
b) What is the tension in the string between the blocks? I think that this can be solved by setting up two equations: m1a = T - μm1g
and
m2a = Fp - T - μm2gThe unknowns in those two equations are exactly what I need -- acceleration and tension. Anybody know how to solve this?!
What have you tried so far to solve them? Hint: Try adding them together.
Yes, I tried adding the two together by solving for T and plugging that equation into the other. Unfortunately, after crunching the numbers, I did not come to the correct answer.
Show what you did.
(Just add the two equations. What happens to the T terms?)
The two equations are:
m1a = T - μm1g
m2a = Fp - T - μm2g
I solved for T as such:
T = m1a + μm1g
Substituting this T value into the second equation, I got:
m2a = Fp - (m1a + μm1g) - μm2g
So,
3a = 24 - (2a + (0.27)(2)(9.8)) - (0.27)(3)(9.8)
Solving for a, I got 5a = 21.35, or a = 4.27 m/s^2. Unfortunately, I do not believe that this is the correct answer.
(Thanks for helping me with this!)
buckybadger said:
So,
No, not correct. Your equation is fine, just check your arithmetic. (Careful with parentheses and signs.)
