Normalizing Free Particle Homework: \psi(x,t)
The discussion focuses on normalizing the wave function \(\psi(x,0) = A e^{-ax^2}\) and deriving \(\psi(x,t)\). The normalization condition is established as \(1 = A^2 \int_{-\infty}^\infty e^{-2ax^2} dx\), leading to the solution \(A = \left(\frac{2a}{\pi}\right)^{1/4}\). The resulting time-dependent wave function is \(\psi(x,t) = \left(\frac{2a}{\pi}\right)^{1/4} e^{-2ax^2 - i\frac{\hbar k}{2m}t}\). The participant expresses concern that the solution appears overly simplistic and seeks clarification on the transition from \(\psi(x,0)\) to \(\psi(x,t)\).
  • Understanding of quantum mechanics wave functions
  • Familiarity with normalization integrals
  • Knowledge of complex exponentials in quantum mechanics
  • Basic proficiency in calculus, particularly Gaussian integrals
  • Study the derivation of time-dependent wave functions in quantum mechanics
  • Learn about the role of the Fourier transform in quantum mechanics
  • Explore the implications of the Schrödinger equation on wave function evolution
  • Investigate the significance of the parameters \(a\), \(\hbar\), and \(m\) in wave function behavior
Students and professionals in quantum mechanics, particularly those working with wave functions and their normalization, as well as educators seeking to clarify these concepts for learners.
E92M3
[tex]\psi(x,0)=Ae^{-ax^2}[/tex]
Normalize and find:
[tex]\psi(x,t)[/tex]
[tex]1=\int_{-\infty}^\infty\psi^*\psi dx[/tex]
[tex]1=A^2\int_{-\infty}^\infty e^{-2ax^2} dx[/tex]
let:
[tex]u=x\sqrt{2a}[/tex]
[tex]1=A^2\frac{1}{\sqrt{2a}}\int_{-\infty}^\inftye^{-u^2} du=A^2\sqrt{\frac{\pi}{2a}}[/tex]
Therefore:
[tex]A=(\frac{2a}{\pi})^{1/4}[/tex]
[tex]\psi(x,t)=(\frac{2a}{\pi})^{1/4}e^{-2ax^2-i\frac{\hbar k}{2m}t}[/tex]
This is too simple to be the right answer. I think I'm missing the point of the question. Please point me to the right direction.
Your value of [itex]A[/itex] is correct; which leaves you with
[tex]\psi(x,0)=\left(\frac{2a}{\pi}\right)^{1/4}e^{-ax^2}[/tex]
How did you go from that, to your equation for [itex]\psi(x,t)[/itex]?
  • · Replies 30 ·
